NC Files
johantabbrink@gmail.com
NC Files
Post by johantabbrink@gmail.com »
Good Day
I have some NC files for Plasma and Router Cut profiles.
Would like to import and save as DXF profiles
Johan
kicktillmonday
Re: NC Files
Post by kicktillmonday »
Good day Johan, give this tool a try https://www.scorchworks.com/Gcoderipper ... ipper.html it has worked well for me in the past. Let us know if it works for you :Like
DIY 4x8 table
Powermax 65
Re: NC Files
That may be interesting as you want to go backward in the process. I see a possible problem as the NC file creation will introduce optional components in the file. Like different g-code elements or functions that are not in a TAP file. I am not saying it cannot be done but will these things effect the end produce, ie the DXF file not being dimensionally correct. I would do some testing with a known DXF file run through a program to generate a NC file and the through the reverse process to check its results. There controller software the will except either type of file and work fine.
Re: NC Files
I have use this in the past with fine results.
G-Code Ripper 6.jpg (64.84 KiB) Viewed 4909 times
G-Code Ripper 8.jpg[/attachment ][attachment=1]G-Code Ripper 9.jpg
Re: NC Files
1001 usa 20 ipm2 .nc.dxf
(19.78 KiB) Downloaded 23 times
1001 usa 20 ipm2 ripped.dxf
(250.05 KiB) Downloaded 36 times
drawing.dxf
(2.38 MiB) Downloaded 18 times
drawing.dxf
G-Code Ripper project.dxf
(24.11 KiB) Downloaded 22 times
