Sprocket file
Sprocket file
I'm looking for a file to cut a 18 tooth 1" bore sprocket for a #40 chain, any help will be appreciated
Re: Sprocket file
I have used this company for years
https://www.surpluscenter.com/Brands/Co ... 3-18-E.axd
- Joe Jones
Re: Sprocket file
Is this what you need?Bently15 wrote: Mon Jun 20, 2022 7:51 am I'm looking for a file to cut a 18 tooth 1" bore sprocket for a #40 chain, any help will be appreciated
Re: Sprocket file
Thanks for the great find Tom! I will most definitely bookmark this one for future reference.acourtjester wrote: Mon Jun 20, 2022 9:11 am I have used this company for years
- SegoMan DeSigns
Re: Sprocket file
They are the best, the majority of the press brake components came from them
They have the best parts / breakdown of any company out there and it is only 2 day ground to get it to KommieRado
Re: Sprocket file
I'm glad to hear that! And fast shipping too.SegoMan DeSigns wrote: Mon Jun 20, 2022 6:23 pm They are the best, the majority of the press brake components came from themThey have the best parts / breakdown of any company out there and it is only 2 day ground to get it to KommieRado
Thanks for sharing your experience with them.
- SegoMan DeSigns
Re: Sprocket file
Yeah I hate sites that take longer to look up the parts than order it, Surplus Center has the ever expanding tree you can select from. Now if I could only fix KommieRado back to where is was Pre-Kaliadbuch wrote: Mon Jun 20, 2022 6:38 pmI'm glad to hear that! And fast shipping too.SegoMan DeSigns wrote: Mon Jun 20, 2022 6:23 pm They are the best, the majority of the press brake components came from themThey have the best parts / breakdown of any company out there and it is only 2 day ground to get it to KommieRado
- Joe Jones
Re: Sprocket file
Wasn't the OP looking for a cut file for the sprocket?
Re: Sprocket file
That was my take on it. Looks like he got 2 optionsJoe Jones wrote: Tue Jun 21, 2022 10:12 am Wasn't the OP looking for a cut file for the sprocket?
Re: Sprocket file
I use this site all the time..and its free
http://www.idleamusements.com/?page_id=367
Re: Sprocket file
Thanks Harry! That's another good source to have. I will most definitely bookmark it for future use.harrymorley wrote: Wed Jun 22, 2022 1:59 pm I use this site all the time..and its free
Re: Sprocket file
Can someone do a 52 tooth for a #40 chain?
- Joe Jones
Re: Sprocket file
What is the roller diameter and the pitch of the chain? .312" x .5", I assume.
You did not specify the shaft diameter, so you may need to change this.
Re: Sprocket file
Joe Jones wrote: Fri Aug 19, 2022 2:27 pm What is the roller diameter and the pitch of the chain? .312" x .5", I assume.
52 tooth #40 sprocket.dxf
It worked perfect. I did scale the center hole to what i needed but, it its perfect. Thanks
- Joe Jones
Re: Sprocket file
I am glad I could help you.jkesler89 wrote: Fri Aug 19, 2022 4:03 pm
Re: Sprocket file
This is a great resource as well. Thanks for that tip.
- ROKCRLER
Re: Sprocket file
I ran across this site and thought you might like, i have not used it yet.
https://geardxf.software.informer.com/
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
