Fusion 360 ignoring small cuts for path
Hi, I have been using Fusion 360 to generate my CAMs for my torch table, whenever i am trying to cut a peice of artwork or a detailed sign it will ignore small cuts and say "Warning: One or more passes were discarded due to linking constraints." For example if my kerf is set to .062 it will not cut an .125 hole. I know it has to do with my kerf width and it not doing it because its "to big". My question is what setting do I need to change to bypass the error or any other work arond.
Re: Fusion 360 ignoring small cuts for path
Also take a look at your lead-ins for your pierces. If the lead-in is too long to fit in the hole or small cutout, it will not generate the cut path for that particular feature and issue a warning.kirby97 wrote: ↑Sat Jan 01, 2022 8:30 pm Hi, I have been using Fusion 360 to generate my CAMs for my torch table, whenever i am trying to cut a peice of artwork or a detailed sign it will ignore small cuts and say "Warning: One or more passes were discarded due to linking constraints." For example if my kerf is set to .062 it will not cut an .125 hole. I know it has to do with my kerf width and it not doing it because its "to big". My question is what setting do I need to change to bypass the error or any other work arond.
You can also just set your kerf width to something really narrow like 0.001" and set your lead-in length to zero. Then it should generate all the cut paths. This is a good way to see which setting is effecting your work.
Kirby97 - were you able to solve our problem using any of the suggestions made above?
I'm with David, just reduce your kerf width.
With a kerf width of .062 x 2 (both sides of the cut) = .124 and your cut profile is .125 Fusion will ignore it.
In general - having the lead-ins too long usually causes most of these problems.
Thanks, that seemed to work.
You are welcome. I assume you mean shortening the lead-ins worked for you.
yes i also made the kerf size smaller. Thanks again.
Hello, new member here. I've just completed a DIY CNC plasma table. I didn't have any experience with CNC or CAD software. I started out in OnShape because I was learning to use a 3D printer. When I decided to learn how to build a plasma table I started learn Fusion.
I can't tell you how many times that I've redrawn this part that I was having trouble with getting a tool path. I had the same problem as the origional poster. I hate to think of how many hours that I've wasted trying to solve this problem.
After reading this thread my problem was solved within 5 minutes.
Thank you guys for sharing your knowledge.
Glad to hear you've got it figured out. Let us know if you run in to any other problems and we will try to help you.Steve59 wrote: ↑Tue May 28, 2024 11:55 am Hello, new member here. I've just completed a DIY CNC plasma table. I didn't have any experience with CNC or CAD software. I started out in OnShape because I was learning to use a 3D printer. When I decided to learn how to build a plasma table I started learn Fusion.
