Voltage Regulator Stabilizer
topkote
Post by topkote »
Hey Guys,
Do any of you run a voltage stabilizer / regulator on your plasma cutter. I might be having an issue with this interfering with my THC. Table is grounded. If you do did it help?
Mike
Re: Voltage Regulator Stabilizer
Hey Mike, that shouldn't be needed. Are you having a problem that you are trying to solve by installing this?
topkote wrote: Mon Oct 04, 2021 8:11 am Hey Guys,
Mike
What are the symptoms of your interference problem? It would probably help if you would describe in detail of your complete setup - plasma cutter, table, controller, software, etc. Photos might also be nice.
