Diy tumbler vibrating deburring tool
TTMotorsports
Post by TTMotorsports »
Does anyone have any diy building a vibrating tumbler type setup to put parts in to deburr them and remove the dross? I've seen some that companies sell and make but I'm more of a diy guy. Thanks
TTMotorsports
Re: Diy tumbler vibrating deburring tool
Something like this.
TTMotorsports
I didn't search and I see this thread below. Gonna get a cement mixer I found online for $50 and give it a whirl.
viewtopic.php?f=85&t=7228
Let us know how it turns out.
I think the concept shown in the post you attached is better for the DIY group, far less complicated to build. Cheap cement mixer :Yay
Post by djreiswig »
I imagine the vibrating type would be quite a bit gentler on the parts as well as much quieter.
TTMotorsports
Anyone have a suggestion on romantic for a drum to spin at aka how many rpm motor and what size pulley. Or how to make a fixed 110v motor variable speed easily
cstroke
Post by cstroke »
I made a quick one with expanded metal for the drum and put it on a pipe threader.
So the speed isnt super fast. It works. Let me see if I can figure out how to post a video.
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
cstroke wrote: Mon Jan 04, 2021 3:08 pm I made a quick one with expanded metal for the drum and put it on a pipe threader.
You could upload your video to Youtube, then post the link.
cstroke
Post by cstroke »
See if this works.
I had a pile of 1/2" parts to deburr and I didnt feel like grinding them.
This was just slapped together.
I think I'll make a stainless one with solid sides and maybe put angle inside, I think I'll try garnet and see if I can clean stainless parts.
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
TTMotorsports
Thats awesome and something I will be making as well. What rpm is your motor turning and what rpm is the basket turning at?
cstroke
Post by cstroke »
I'm not sure what it turns at... It's a Rigid 300 pipe threader. I did a quick search on what RPM's they turn at and didnt come up with anything.
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Rodw
Post by Rodw »
Thefabricator on this forum made a "small" one
Detailed build: https://forum.linuxcnc.org/plasma-laser ... ts?start=0
