Mach3 Plasma ScreenSet
FabLab
Post by FabLab »
Hi All,
I have been working on a plasma screenset for Mach3 and here is what I came up with.
The biggest thing I wanted was a simple screen with a large tool path display area.
This is totally customized for my setup, so your mileage may vary :) My monitor uses a screen resolution of 1920x1080 and I have disabled Auto Screen Enlarge in Mach3
The Park button is used to move my machine to its max + travel (Home is the max - travel) the button just "parks" the machine at the max + position. if you would like to use it you would need to set G59 to your max + position & set the button to use the following script:
Code ("G59 G0 X0 Y0 Z0")
While IsMoving()
Wend
Code ("G54")
The SawCut button doesn't work yet ignore it for now
Here is an image of the screenset:
PlasmaScreenSet.zip
(4.04 KiB) Downloaded 386 times
PlasmaScreenSet.zip
PlasmaScreenSetw4thAxis.zip
(7.79 KiB) Downloaded 327 times
Re: Mach3 Plasma ScreenSet
Hands down the cleanest Mach3 screen I have ever seen. Well done :Like :Like
rrossetti
Post by rrossetti »
what is saw cut?
FabLab
Post by FabLab »
weldguy wrote: Mon Jan 20, 2020 10:17 am Hands down the cleanest Mach3 screen I have ever seen. Well done :Like :Like
Thanks I appreciate that!!
FabLab
Post by FabLab »
rrossetti wrote: Mon Jan 20, 2020 3:39 pm what is saw cut?
What I am working on with that is whenever you hit that button a series of prompts will come up asking for X-Y coordinates and a feed rate in order to cut free the waste material and leave me with straight cut drops...
Hope that makes sense
would not that be easier to add those things to your cut plan in SheetCam nesting Just add shapes.
FabLab
Post by FabLab »
acourtjester wrote: Thu Jan 23, 2020 8:20 pm would not that be easier to add those things to your cut plan in SheetCam nesting Just add shapes.
Sometimes it is, but a lot of the time I will cut some parts, leave the sheet on the table and come back a few days later and cut a few more so I never really know how or where I want to "saw" the sheet until I go to pull the sheet off.
Its one of those things I don't really need its just something I figured would be nice to have :Yay
robertspark
Post by robertspark »
Reuse the job file in sheetcam and add some homing switches to your machine so that sheetcam knows your offset for the sheet?
FabLab
Post by FabLab »
I have homing switches and your right I can and do that part of the time.
Like I said before it's not something I need it's just an option I thought I might like to have.
Plus it gives me a chance to learn more about the inner workings of Mach and just play around a bit
rrossetti
Post by rrossetti »
FabLab wrote: Thu Jan 23, 2020 8:15 pm
so you mean rip cut
i can send you the macro if you like
FabLab
Post by FabLab »
rrossetti wrote: Sat Jan 25, 2020 10:27 am
so you mean rip cut
Yeah that would be cool!!
Blackslacks
Post by Blackslacks »
Is it possible to add this (or any other screen) to an existing screenset and be accessible via new screen tab? Thanks
robertspark
Blackslacks wrote: Tue Jan 28, 2020 10:10 pm Is it possible to add this (or any other screen) to an existing screenset and be accessible via new screen tab? Thanks
Yes
This post shows how to make changes to Mach 3 screensets be sure to copy the one you want to change first.
https://www.plasmaspider.com/viewtopic. ... en#p178082
Blackslacks
Thanks jester , but I want to add an existing stand alone screen to the default Mach3 screenset, not modify an existing one. I don't think that's covered in the link. Can you tell me how to do that?
robertspark
Save the screenset to your mach3 folder
Load mach3
Across the top menu line there is an option to change / load screenset under one of the menu options .... I think it is operator settings or something like that
Not sure which answer you want
for the loading of the above screen set unzip the file he posted then copy the file Plasma1900X900.set to the main Nach 3 folder.
Then run Mach and go to view and click on load screens and select that from the selection of screen sets displayed, screen goes blank for a second and the the new screen displays. :Wow
different answer here
Ok go to the Mach 3 folder and then to the mslbackups folder. Pick a backup file the has a close to current date and click to copy it then paste it there it will have a name with copy in it. The click on that file and rename it what ever you like. Click on is and copy it then go to the Mach 3 main folder and paste it there, then rename it by just changing the extension to .XML it will ask if you want to do it say yes.
This will change it to a XML file with that name you choose. Now find the file in the main Mach 3 folder called Mach3 type application and click on it to run it you will get the menu with all the profiles available and select the new name you gave it. Another menu will come up called motion control hardware plugin sensed and select what your using. This will open the normal screen that you can now make changes to for the new screen you create. :Like
test 3.JPG (47.12 KiB) Viewed 13672 times
test 4.JPG (33.17 KiB) Viewed 13672 times
Simpler way is to run the Mach3 application from the Main Mach 3 folder it will bring up Session Profiles menu just select Create Profile. :Yay
Another menu will come up plug in the new name you want and select it and make changes to it done.
test 5.JPG (33.47 KiB) Viewed 13672 times
Post by djreiswig »
I think he wants to add the page from the screenset to his existing screenset.
You will have to download the screen editor from the mach site and copy it with that.
Blackslacks
Thanks everybody for their input. Yes djreiswig that's exactly what I want to do. Ive dl'ed both Screen4 and Mach3screen and I'll see if I can figure it out. Thanks again.
robertspark
This is the one I've used in the past
https://kd-dietz.com/pages/eng/machscre ... ption.html
rrossetti
Post by rrossetti »
Rich_H
Post by Rich_H »
If you load a different screenset into Mach 3, does it automatically pick up the same settings as the original one?
It has been a while but I would say no, but some of the setting are global. The setting for the motors are kept, setting for the pin numbers may change. There are really not that many, I would look at the setting on the screen you and to change and write them down for checking afterward. Now if you use Screen 4 and modify a screen and save it as the same most likely you are adding or changing buttons or locations so only those thing will change. I added this LED to my program page so I could see when the ohmic sensor working. It was saves as the standard Plasma screen set.
rons
Post by rons »
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
tim7878
Post by tim7878 »
hey, love the screen. really clean. anybody here know of a mach3 screen set for plasma with a 4th rotary axis? ive tried modifying the mach screen but its just honestly a little beyond me. i am happy with just the basic mach3 plasma screen, i just need the rotary axis. thx.
Return to “Mach3 & Mach4 CNC”
