Phase 2.
Here we go everyone.
Let me say first off that the biggest pain in the neck SO FAR for me has been making sure these 1/2 CRS are exactly parallel and dead on.
I checked....checked....and then rechecked everything. Where the 2 butt up to each other is a bit of a pain. Due to CRS warping like crazy which I knew about I made sure to do all I could to make sure that did not happen. And honestly it wasn't that bad but it did have a little. not a a crazy crazy amount like I was totally expecting.
So fyi stitch it in and grind it barely basically. It works....not the greatest in my opinion but it works.
So my wife and i drilled about a million holes. Did the CRS on the bridgeport and then i started on the end and used the directions in the blue prints to make one side wicked straight...got that gantry tight on it....and then used it as a jig basically to get the other side into action. I still...as ridicules as it may be i still checked the other side with a string...then a laser...
Cant tell you how nice it is to get some help in the garage.
Whats funny is typing this up its so simple to be like yeah drilled about 10000 holes but the actual physical act is much much more.
Anyways back to the story. I did screw up some of the holes thanks to a few bits that i got that just gave up on me pretty much 20 min into their working life so that was nice. Anyways. If you screw up you can always re drill and retap if you have to. Its not the end of the world.
Here I have the gantry mocked in basically. where i basically cut everything to length to see how far or close it pushed or pulled anything out. You can move the bearings in and out a little for sure to make it where both side are hitting the back stop at the same time.
Pretty sure i got carried away welding that gantry. should of just welded a little and been done but over the course of weeks id hit it with some weld...then again...check how out of square it would get me and then weld a little more.
But in the end i got that rail extremely straight for 22 ft long....
This whole gearing concerned me way more than it should have. Seriously that was easy. LOCTITE BLUE is ordered and not here yet. Once it is that will all come apart after everything is dry fitted with the electronics. Then I will do it all again with Loctite. like....all of it....
Putting the gearing on the back of the gantry. littleeeee over kill on the clamps i think. Cleaned the crap out of this with rubbing alco....it was like wiping the top of a jiffy jar at one point...it just didn't feel like it was ever coming clean. I was like am I going crazy am i re-wiping this with dirt what the crap. but it eventually cleaned up nice.
The gearing under it went in really well too.
I purchased the electronics those are due to be in in about 3 or 4 weeks.
I went with the Quincy 7.5 hp 80 gallon max unit. That was to be delivered today...then it didnt....maybe tomorrow.
So the new few updates I plan on making are one for air install, electronics, plasma hook up and odds and end more than likely.
Again any comments concerns hit me up.
