Want to 'free-hand', but...
jeepen
Post by jeepen »
Hey all, new here... I'm equipped with a 45XP, and the desire to cut designs, by free hand. To explain, I'm completely new to plasma cutting. I've used aids like circle and straight line jigs. But I want to cut some logos and artwork, without software, etc. I thought I'd chalk out some lines on regular soft steel plate. But with the flash and all, I can't see the lines... and it looks sh*tty, really bad.
What to do? Thxs, beginner.
Re: Want to 'free-hand', but...
Post by djreiswig »
Do you have a shade 5 face shield? That should help with the arc flash.
ben de lappe
Post by ben de lappe »
Yep, shade 5 and soapstone lines you'll be able to see the cut much better. Soapstone being white and powdery upon application shows up bright white in the lighting of the arc.
Available from your local welding supply store.
