New Samson 510 table new options
hoodgurl_unarmed
Post by hoodgurl_unarmed »
Just got a Samson 510 table , hypertherm 65 ,with design edge software. With my old trucut table and software I could click "run from here" and start where the table stopped or missed a cut even if it went through the whole file, so my question is how can I do that with my new machine. Thank you.
bigcreek
Re: New Samson 510 table new options
Post by bigcreek »
I am probably not understanding your question correctly, but if my torch misfires a thing comes up on the computer screen asking me if I want it to continue cutting from where it last stopped cutting or something like that.
motoguy
Post by motoguy »
Samson is the same as Plasmacam, so asking Plasmacam users may find your answer.
rdj357
Post by rdj357 »
If a red dot comes up and you don't unselect the remaining to cut paths, it will ask you if you'd like to resume where cutting stopped.
If you're trying to finish a bunch of cuts and have either accidentally unselected the remaining cuts or otherwise need to continue from one path to the end, here's a video I did. This topic starts at 30 minutes in.
https://www.facebook.com/learnplasmacam ... 003642722/
Robert Johnson
PlasmaCAM GURU & Instructor
hoodgurl_unarmed
Thank you, I wanted to start just a little bit before it stopped. But still have not figured out how to go back. With the trucut table I can go to a specific spot and recut a place that did not cut correctly. Thanks for the help.
Kit Barlow
Post by Kit Barlow »
Restart the cut but before it fires hit stop on the controller and then use the shuttle dial to track along the cut line. This makes the machine follow the cut path. Once you track to where u want to start. Hit the start button. Hope this helps
