I am needing to further automate so I am looking to simplify the process of tool path/lead in creation
I am now using Enroute, and I like all aspects of it EXCEPT?.toolpathing/lead ins?..I mostly do metal art???.so it is not un common to have a drawing with 20, 30, 40, or even 50++ closed vectors??..with Enroute I have to set a separate toolpath/lead in pretty much for each and every one?.because there will be a range of closed vector sizes from .25 inch to 3 or 4 inches in size ??..and so for a 2 inch object, a .40 inch length lead in at 10 degree internal approach will not work on a .25 diameter shape that needs a .10 inch lead in with a 80 degree approach?.??.otherwise the torch will cut across the object and obliterate the intended shape
I spoke with Enroute tech support and they say ?we have been talking about it? but no joy on the other end of the phone???..
So I am thinking that there is hopefully software for toolpathing/lead in set up that will AUTOMATICALLY look at the max dimension of each and every closed vector object, regardless of object size, then AUTOMATICALLY create a toolpath/lead in length AND approach angle based on the objects size and orientation on the drawing
Any suggestions?
Thanks guys
Marty
auto toolpath/lead in setting
1 post
• Page 1 of 1
- Marty
Ignition Metal Art Design
Give a man a fish and you have taught him where to come for a fish; Teach him to use Google and the Search Engine on Plasma Spider and he will be able to learn more than you could ever teach him yourself
1 post
• Page 1 of 1
Jump to
- Welcome Hub & Meet Our Sponsors
- ↳ Contributing Membership Upgrade
- ↳ Introduce Yourself
- DXF Design & Project Picture Sharing Forums
- ↳ DXF & SVG Categorized Library
- General Forums
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- Plasma Cutter Forums
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- CNC Plasma Table & Controller Forums
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FastCut CNC Website
- ↳ FlashCut CNC Forum
- ↳ FlashCut CNC Website
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Shop Sabre Website
- ↳ Star-Lab CNC Forum
- ↳ Star-Lab CNC Website
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- ↳ Tracker CNC Website
- CAD-CAM & Control Software Forums
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ CorelDRAW Free 15 day trial
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- Metal Finishing Forums
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- Accessories & Tool Related Forums
- ↳ Laser Engravers & Cutters
