Texturing steel before painting?
Learn and share abrasive & texturing finishing techniques, experiences, and product knowledge here.
wishiwastorching
Post by wishiwastorching »
I am looking for a texured effect to hide scratches and dings in some 4.5 inch letters I'm cutting out. I like rustoliums "hammer" paint but it does not come in the color I need. is there something out there i can create this effect with then paint over it???
Thanks!!!
Matt
hacnwac
Re: Texturing steel before painting?
Post by hacnwac »
I have seen other pieces done like this but I personally have not tried it yet (but going to) is to spray gravel guard or stone protector. Its the stuff people spray around the bottom of vehicles to help protect paint from stone chips. Check with automotive suppliers and they can probably tell you what can be used and painted over.
Mark
Gamelord
4.5 Star Member
4.5 Star Member
Post by Gamelord »
Truck bed liner works great too.
Torchmate CAD
wishiwastorching
Thanks for the ideas but those both sound like they are pretty heavy on the texture. Im looking for more like the "hammer" paint type look. Not a heavy texture but just enough to hide the minor flaws.
tnbndr
Post by tnbndr »
Why not use a hammered paint and then paint over it with the color you want?
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
wishiwastorching
That is what I'm going to do if there isnt another good suggestion. I did it once before and it took a lot of paint to cover it up. Just shopping for other ideas.
Diverdude
Post by Diverdude »
try Gravitex, I,ve used it before and it works nicely. It sprays smoother than bedliners to give the finish you described and can be painted over with most paints. http://www.autobodytoolmart.com/u-pol-g ... 15137.aspx
PlasmaRoute HD 4x4
ryno fab
Post by ryno fab »
what about going the other rout and fixing the dings. when i do truck bumpers i end up with deep grinder gouges, rust pits, and the like there and there. i went to napa and got some "icing". its basicaly thin bondo. i know i know bondo is a dirty word. for filling small stuff it works geat. drys fast. super smooth finish.
Scott Briggs
Post by Scott Briggs »
Get a neddle scaler for removing slag. It will put a dimpled look on your metal if ou use enough preasure.
5X10 PlasmaCam
Hypertherm 45
Miller 252
Miller 212
Lincoln 215
Lincoln 185 Tig
100 ton Break Press
http://www.scooterbiltmanufacturing.com
DieselMonkey
Post by DieselMonkey »
Use stone paint from lowes/home depot ect.
Works great, not as thick as truck bed liner
After its dries paint it whatever color
Few problems in life can't be solved with the generous application of a cutting torch and a taco truck.... or something like that.....
JJsCustomDesigns
Post by JJsCustomDesigns »
tnbndr wrote:Why not use a hammered paint and then paint over it with the color you want?
wishiwastorching wrote:That is what I'm going to do if there isnt another good suggestion. I did it once before and it took a lot of paint to cover it up. Just shopping for other ideas.
I buy FUSION rattle cans from walmart. I think they have several colors. I usually go with a black. Most of my items are painted dark so if i miss a spot its not noticeable.
PM me with details
Return to “Abrasive & Texturing”
