4X4 Truck parts
Scott Briggs
4X4 Truck parts
Post by Scott Briggs »
Where's all the crazy 4x4 junkies at? Does anyone have any cool suspension parts drawn up?
5X10 PlasmaCam
Hypertherm 45
Miller 252
Miller 212
Lincoln 215
Lincoln 185 Tig
100 ton Break Press
http://www.scooterbiltmanufacturing.com
Gamelord
4.5 Star Member
4.5 Star Member
Re: 4X4 Truck parts
Post by Gamelord »
Ya may want to check out Pirate4x4
Torchmate CAD
IHscout
Re: 4X4 Truck parts
Post by IHscout »
What are you looking for? I just drew and burnt a sh@t load of link brackets for 60"s and 2.5 tons for my buddies. Plates for 8274's, plates for the standard warn winches.
I'm not on here very often, the quickest way to get ahold of me is either email or text. csfabworks@gamil.com or 1-636-744-5868. If I have it I'll give it to you.
Let me know.
Scott Briggs
Re: 4X4 Truck parts
I'm just trying to encourage everyone thats into 4x4 to talk about that stuff. Its just something that Im into. I like to see what others are doing.
Scott
5X10 PlasmaCam
Hypertherm 45
Miller 252
Miller 212
Lincoln 215
Lincoln 185 Tig
100 ton Break Press
coyote577
Re: 4X4 Truck parts
Post by coyote577 »
A few hundred I just built a 86' toy crawler sas'd doubler so on.
goto http://www.texas4x4.org/burntables-134/ ... les-44119/ for more dxf files for 4x4 trucks.
Scott Briggs
Re: 4X4 Truck parts
Sweet, thank you coyote.
Scott
5X10 PlasmaCam
Hypertherm 45
Miller 252
Miller 212
Lincoln 215
Lincoln 185 Tig
100 ton Break Press
Nacs Fab
Re: 4X4 Truck parts
Post by Nacs Fab »
I designed and drew up a leaf spring mount for a SAS on a 95 Ford Explorer and had it waterjet cut. It worked out real good. Now that I have my CNC Plasma, I'll make a bunch more of these eventually.
Have you downloaded the standard 4x4 offerings such as NP203 and NP205 adapters, disc brake caliper mounts and so on from Offroad Fab Net?
They have some good stuff for free there.
G540 with LCTHC by candcnc
all built... by me...
coyote577
Re: 4X4 Truck parts
Post by coyote577 »
No I haven't I have a t-case mounting brackets and disc brake swap brackets for toyota and all kinds of tabs some armor and braces for diff's some 203 205 stuff and 14 bolt stuff and a little bit for tons.
coyote577
Re: 4X4 Truck parts
Post by coyote577 »
I got bored so I made some pole dancer beadlocks. They are not very practical, but it is a good exercise for making dxf files.
To make the weld on ring copy the outer ring and bolt holes then draw a inner ring about 2.5 inches smaller radius.
Scott Briggs
Re: 4X4 Truck parts
Haha, that's cool man!
5X10 PlasmaCam
Hypertherm 45
Miller 252
Miller 212
Lincoln 215
Lincoln 185 Tig
100 ton Break Press
Scott Briggs
Re: 4X4 Truck parts
I love off road stuff, but I'm still in the learning stages of trying to figure out how everything works. I'm capable of building anything, just not into the trial and error part when there is so much info out there these days. I have some really cool 3 and 4-link Ideas I will pass along when I get them drawn up.
Scott
5X10 PlasmaCam
Hypertherm 45
Miller 252
Miller 212
Lincoln 215
Lincoln 185 Tig
100 ton Break Press
coyote577
Re: 4X4 Truck parts
Post by coyote577 »
Here is my baby, I've been welding for 20+ years just getting into cut tables and off-roading it seems that the two are meant for each other. I design and build a lot of equipment on autocad but drawing or converting into G-code is sometimes a challenge.
Scott Briggs
Re: 4X4 Truck parts
A buddy and I sat in my office one evening and did a rough design on what we call a rock buggy body. It will be burned out of 14-16ga sheet metal. Some of it will be broke on my break press then all the pieces welded together. The plan is to build the structure strong enough that no internal roll cage would be necessary. This body could be used for almost any type of racing.
Last edited by Scott Briggs on Mon Dec 10, 2012 10:18 am, edited 2 times in total.
5X10 PlasmaCam
Hypertherm 45
Miller 252
Miller 212
Lincoln 215
Lincoln 185 Tig
100 ton Break Press
coyote577
Re: 4X4 Truck parts
Post by coyote577 »
badass
coyote577
Re: 4X4 Truck parts
Post by coyote577 »
This is for you np-203 fans.
Scott Briggs
Re: 4X4 Truck parts
Here is my truck. I have a set of stacks and a light bar built for it, I just haven't had the time to put them on. This is what I'm wanting to build a nice custom 4-link suspension for.
5X10 PlasmaCam
Hypertherm 45
Miller 252
Miller 212
Lincoln 215
Lincoln 185 Tig
100 ton Break Press
Binderman
Re: 4X4 Truck parts
Post by Binderman »
IHscout wrote:What are you looking for? I just drew and burnt a sh@t load of link brackets for 60"s and 2.5 tons for my buddies. Plates for 8274's, plates for the standard warn winches.
Let me know.
I noticed your user name......... S2 or 80/800?? I have a 800A.
Anyone have a SAS file for a 89 S-10??
cbassjr
Re: 4X4 Truck parts
Post by cbassjr »
I'm kinda a dumb ass so what does SAS mean.
c&hrodshop
Re: 4X4 Truck parts
Post by c&hrodshop »
Solid axle swap
MIFab
Re: 4X4 Truck parts
Post by MIFab »
coyote577 Is the brake bracket for a 14 er what?
HorseN
Re: 4X4 Truck parts
Post by HorseN »
portable winch mount .dxf
Binderman01
Re: 4X4 Truck parts
Post by Binderman01 »
Does anyone have a link for the 203/205 adapter? I also found a 231/300 adapter the other day and can't find it now. Anyone have the links?
CW_Cutting12
Re: 4X4 Truck parts
Post by CW_Cutting12 »
Can we Bump this page. There is some good stuff in here but i know there has t be more out there.
zakscott22
Re: 4X4 Truck parts
Post by zakscott22 »
i have some more for link tabs and what not, need to go thru and get them put together and ill share them
zakscott22
Re: 4X4 Truck parts
Binderman01 wrote: Mon Jan 04, 2016 9:03 pm Does anyone have a link for the 203/205 adapter? I also found a 231/300 adapter the other day and can't find it now. Anyone have the links?
Id be interested in the 231/300 if you find it
