plasma cam error
skiwithnoskis
plasma cam error
Post by skiwithnoskis »
I need some help. Today while cutting the machine started acting sketchy. It will cut for a while two three cuts maybe. The i get a cutting signal lost message (may no be the same verbage). I have a good ground and new consumables. If i initialize the machine i will do a few more cuts before giving me the error again. Plasma cam dhc2 and ht 1250
Thanks for the help
BB
Francisco
Re: plasma cam error
Post by Francisco »
Check the control cable connections to your 1250's board for looseness. Check it for continuity end-to-end from the two trigger wires and the clamp (+/thick black wire) to the miniDIN connector which goes into the controller. There are five pins in this connector. One is nor used; the other one should show a 680 kOhm resistance against the remaining board connector (-/thick red wire). Finally, there should be 33 kOhm -or so- between the two arc voltage wires.
I hope this works for you
