trouble with corel x3
I recently had to have my computer restored to original. I pulled all my files before we had to do it. I loaded corel x3 on the computer after the restoration and now it doesnt work right. I have my disc i enter my activation code and everytime i try opening a file on plasma spider it comes up with do you want to allow the following program to make changes to this computer and i click yes and then it pops up saying the was a problem sending the command. I am not sure what to do can anyone help me
- Gamelord
- 4.5 Star Member
Re: trouble with corel x3
Not sure if this is the issue or not, but you may want to make sure you have all the updates loaded. Open go to the update menu (I think it is on the last option) and check for updates.
Torchmate CAD
Torchmate CAD
first, make sure windows opens dxf with corel draw,
in windows explorer, double click a dxf file and see if it opens in corel
if not, right click on a dxf, slide over open-with and hit choose-default-program, then select corel draw and check to always use the selected program.
then in windows explorer you should be able double click to open a dxf file in corel
get that working first......
then it will be easier to get opening over the internet working
