CENTURY 50amp, on CNC table
b2krawler
Post by b2krawler »
wondering if anyone is running a old school Century 50amp plasma cutter on a CNC table
pre-inverter Century 50amp, with machine torch on Torchmate table
Rockrunner86
Re: CENTURY 50amp, on CNC table
Post by Rockrunner86 »
I would venture to say no.
twicecustom
Post by twicecustom »
I had an old TD on my machine at first, it created a lot of noise that I couldnt get rid of. But if you got it, it might work for you. Worth a try.
Jack of all trades, Master of none.
Benjiman
Post by jimcolt »
Some of the earlier Century plasma's used high frequency start......then they switched to blowback start. If it is a HF start....it will be problematic on some cnc machines....without proper grounding as well as shielded wiring and cables.
A picture of the torch and the consumables will help me determine which type of start technology it has. Likely the torches are Hypertherm manufacturerd.
Jim Colt
b2krawler wrote:wondering if anyone is running a old school Century 50amp plasma cutter on a CNC table
