Cutting Expanded Metal - Which Macine Best
[o]
- Team Tracker
Re: Newbie with questions
See this older post on cnc zone http://www.cnczone.com/forums/cnc_plasm ... hines.html
This individual has a Hypertherm 1000 doing a great job on perforated metal.
1-800-590-7804
The Hypertherm units have a special pilot arc controller and a selector switch on the front panel specifically designed for cutting expended metal. When cutting over metal, the arc is cutting normally....as soon as a hole is sensed, the pilot arc controller quickly lowers the current to minimize nozzle wear....and rapidly ramps it back up when it gets back over the metal. You will have to put the height control system into manual mode for cutting expanded metal.
Jim Colt
Jim Colt
Thanks Jim.
Very useful info. I appreciate it.
- BrianMick
Re: Cutting Expanded Metal
I have a hypertherm 1650 with this feature and think it works greatjimcolt wrote:The Hypertherm units have a special pilot arc controller and a selector switch on the front panel specifically designed for cutting expended metal. When cutting over metal, the arc is cutting normally....as soon as a hole is sensed, the pilot arc controller quickly lowers the current to minimize nozzle wear....and rapidly ramps it back up when it gets back over the metal. You will have to put the height control system into manual mode for cutting expanded metal.
Jim Colt
www.midwayiron.com
www.midwayiron.com
I have a Dynatorch with a Hypertherm 1250. Cutting expanded metal is easy: turn off the THC and flip a switch on the front of the Hypertherm. Start the cut over metal portion on the EM.
- Dennis
I cut expanded metal on my Fastcut table works great..
- Scratch
I have a TD 151 and it cuts expanded metal fine also. I image most of the big names will cut it fine. TD has a setting for it.
