Grind Zilla #7 For Sale
Buy and sell used plasma cutting and related equipment here.
DIY Belt grinder for sale, I have build 7 of these grinders using Jeremy Schmidt's construction plans, with upgrades to design. This grinder has a 2 HP 3 PH motor with VFD for converting 220 Volt AC standard house voltage. The VFD has a remote control panel which can be located away from the grinder itself for on/off and speed controls.
Construction is 2” square tube, 2.5” square tube, and 3/8” plate. Most of the grinder is Powder coated for looks and easy cleaning. Aluminum wheels with sealed bearings one is used as a tracking wheel and is fully adjustable for aligning the belt while in use. This is commonly called a knife grinder, not being a knife maker I use it as a standard shop grinder for many projects. The platen can be removed for a slack belt type grinding to shape metal. It has a table for a flat surface to maneuver what is being ground, which can be adjusted to a 45 degree angle. The grinder can be rotated from a horizontal to a vertical to change the grinding direction relation to the table. Comes with 2 new belts for the grinder. Price is $950. cash picked up at my location only. This is the last one I will construct, at 82 I have other projects to do. :HaHa :HaHa
Re: Grind Zilla #7 For Sale
Tom - that's a great looking sander/grinder and your presentation is top notch.
Return to “Classified Ads”
