Finecut vs Regular cutting
Nhighley4
Post by Nhighley4 »
I have a pretty detailed sign coming up, I’m looking at different options for cutting. Kerf between a regular hypertherm 45 amp nozzle and a hypertherm 45amp finecut nozzle isn’t as drastic as I thought it would be. Looks like .055 vs .049. Is it worth designing the piece to work with finecut? Just doesn’t seem like it makes that big of a difference. Is there another perk to finecut that I’m missing?
SegoMan DeSigns
Re: Finecut vs Regular cutting
Post by SegoMan DeSigns »
You did not specify the metal thickness to be cut. The fine cut gives you a much cleaner cut, I do up to 1/8 with mine, some push it to 3/16".
Nhighley4
Post by Nhighley4 »
Apologize, 14ga mild steel.
SegoMan DeSigns
I just finished a cut and delivered it to the customer with the same material or I would take a picture of it for you.. I'd say give it a try just make sure you have the right nozzle and shield.
I'm a fan of Bakergas for consumables.
Nhighley4 wrote: Tue Mar 18, 2025 12:03 pm I have a pretty detailed sign coming up, I’m looking at different options for cutting. Kerf between a regular hypertherm 45 amp nozzle and a hypertherm 45amp finecut nozzle isn’t as drastic as I thought it would be. Looks like .055 vs .049. Is it worth designing the piece to work with finecut? Just doesn’t seem like it makes that big of a difference. Is there another perk to finecut that I’m missing?
I normally used FineCuts on steel material 11 ga. and thinner. The benefits of FineCuts include narrow kerf width for better details and reduced heat to help minimize warping on thinner materials.
I'm not sure how you would design a piece specifically for FineCuts. I suppose it might depend on whether you are doing mechanical parts with tight dimensional tolerances or artistic pieces.
Nhighley4 wrote: Tue Mar 18, 2025 1:54 pm Apologize, 14ga mild steel.
For 14 ga. steel, I use Hyperthyerm "book settings" with the exception of cut speed, which I reduce to around 185 - 190 ipm. Also - with new FineCuts, it is recommended to set your cut height to around 0.070" or so for the first several hundred pierces. Then drop back to the standard 0.060" setting.
Nhighley4
Post by Nhighley4 »
That’s also great info. I think I’m going to try it for the warping aspect of it and some other smaller details. Appreciate all the help, will definitely apply the .07” cut height for this first go around and see how my table does. Thank you
Nhighley4 wrote: Wed Mar 19, 2025 10:49 am That’s also great info. I think I’m going to try it for the warping aspect of it and some other smaller details. Appreciate all the help, will definitely apply the .07” cut height for this first go around and see how my table does. Thank you
:Like :Like :Like
