Few month ago, i got a new jobs as R&D Tech and heritated of and unfinish project, a "Custom build Plasma table/rotary"
My issues:
- After running for few minutes(5 to 15mins), when it come time to probe before the next cut, i get an error about "Active probe" and it stop there.
Thing i've tryed & observation:
- I grounded the table on different metal object surrounding the table (different big metal table, a huge press).
- when a cut is finish, there is air blowing out the torche for few second and my "touching LED" on the probe pcb stay ON until the air stop blowing.
- I swapped the nozle on the torch with a new one and the problem didn't follow (im using "Hypertherm Finecut Mechanized Cutting 428926").
- I added dwel time in the program to wait until the air stop between cut but didn't work.
- On the rotary i don't get this problem only on the table while cutting flat stock
Hardware & software:
hypertherm powermax65
Mach4
4" Water table (it was leaking so the level of water was very low (not even 0.5" of water) and was at 3" away from material)
controler: Pokeys57cnc
I've added few picture of the machine. If anyone have some idea i am gladly taking them.
Alain
