Fire starter box DXF
Jakessler1
Post by Jakessler1 »
I was hoping that someone had a DXF file for a kindling box or fire starter box (sometimes known as a chimney). I wanna use the new table I got and need a chimney for the smoker so why not mix the two.
Re: Fire starter box DXF
Jakessler1 wrote: Tue Feb 25, 2025 3:25 pm I was hoping that someone had a DXF file for a kindling box or fire starter box (sometimes known as a chimney). I wanna use the new table I got and need a chimney for the smoker so why not mix the two.
Please post a photo (look on internet -do an image search) so we can better understand exactly what you are looking for.
BMCF
Post by BMCF »
Here's one I made. I dont have completed pics on my PC. I used a piece of 1/2" rod for the handle and tacked a spring handle onto it( you could also use wood). It also has a heat shield so you dont cook your knuckles. You will have to contour it to fit your hand.
Chimney-All 3 Files.dxf
my charcoal chimney SQ 6in 12in tall one hole for handle.dxf
my charcoal chimney SQ 6in 12 tall grate.dxf
my charcoal chimney heat guard.dxf
maghunter120
Post by maghunter120 »
BMCF wrote: Sat Mar 01, 2025 3:38 pm Here's one I made. I dont have completed pics on my PC. I used a piece of 1/2" rod for the handle and tacked a spring handle onto it( you could also use wood). It also has a heat shield so you dont cook your knuckles. You will have to contour it to fit your hand.
Very nice. Just what I've been looking for. Thank you.
