Logo to Cut file
smilintodd
Logo to Cut file
Post by smilintodd »
Hello, was wondering if anyone has some good ideas to cut this Logo and make it look nice for a squat rack tag. The sports performance program for our university would like to make these for all the squat racks, but as it is, is pretty detail and obviously not going to look like the picture since nothing is attached.
Todd
Stand Alone Logo (BLUE BACKGROUND).pdf
05Duramax
Re: Logo to Cut file
Post by 05Duramax »
The logo looks very doable. I would start by completing the entire outline of the logo then for the inner detail don't be too particular about keeping it exact, you will need to modify it a little keep things from falling out. For example the detail in the weights will fall out but if you connect it together in spots you can get the look you want without it falling apart. Have you started on this yet so you can show us what you have so far? What is the finished overall size of this logo to be?
smilintodd
I haven't started on it yet, but I'm wondering if i should look at laser engraving the logo and cutting out the number.
05Duramax
Post by 05Duramax »
Laser engraving would be a better option if you were planning on keeping this small but if it was to be larger enough to plasma cut that woudl be much cooler I think.
If I am getting the scale correctly, your logo looks to be maybe 4x4 to 6x6 inches in size. What is the actual size you want to cut it at? The answer will help to determine the best options for cutting/engraving/scribing.
Todd - did you have any success creating your finished logo using plasma cutting and/or engraving?
smilintodd
Sorry for the late response, Im going to end up laser engraving. I have a buddy that has a small laser and we will use a marking coating and laser it on stainless.
smilintodd wrote: Fri Apr 04, 2025 1:16 pm Sorry for the late response, Im going to end up laser engraving. I have a buddy that has a small laser and we will use a marking coating and laser it on stainless.
:Like :Like :Like
