Fine Cut Nozzles Shielded or Non- Shielded
Geanvert
Post by Geanvert »
Hello, I currently have the unprotected Fine Cut consumables, is there a real difference in cutting quality with the protected Fine Cut?
Thank you
weldguy
Re: fine cut
Post by weldguy »
I don't believe you will see any difference in cut quality between the protected and un-protected Finecut setups. The only difference I see is that the protected or shielded setup will help to protect the nozzle from molten metal sticking to it during the pierce cycle. This is helpful when piercing thick material but when using Finecuts it typically thinner material and pierce times are super fast and I don't see a real use for them.
Geanvert
Re: Fine Cut Nozzles Shielded or Non- Shielded
Post by Geanvert »
very good, thanks for the feedback.
Dirtmotor
Post by Dirtmotor »
I have tried both , I think the shield helps the tip last longer .
If you are using Ohmic sensor contact the shield must be used for the circuit to work.
Geanvert
Post by Geanvert »
on occasion I would order a specific shield. THANKS
SeanP
Post by SeanP »
For me the unshielded works lot better for some reason, galvanized, stainless and ally were a right pain with the ohmic shield.
When I did try ohmic sensing I ended up setting a pin/leg into a finecut deflector, that worked well and less trouble with spatter, back to floating head sensing for a few years now, more trouble than it was worth for me.
I also raise the air pressure on the machine to 4.9bar (71lb) which again makes for better cuts I find.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Geanvert
Post by Geanvert »
what do you mean by pin or foot? a photo would be welcome. thank you
SeanP
Post by SeanP »
Powermax XP45
Table build gallery
Deezl Smoke
Post by Deezl Smoke »
Interesting. I though the shield was to cool the nozzle, at least on my PM105 mech torch, the fine cut shields have holes for air flow.
Geanvert
Post by Geanvert »
but you drilled the shield yourself to put a key in it?
Deezl Smoke
Geanvert wrote: Sat Feb 08, 2025 2:33 am but you drilled the shield yourself to put a key in it?
Nope. I'll get a picture later today. It's been a while since I used fine cut, but iirc, the shield has holes just like the other shields, only the fine cut is a much shallower shield.
Deezl Smoke
Couple of my fine cut shield and nozzle.
Geanvert
Post by Geanvert »
so this is the protected version.
Geanvert wrote: Sat Feb 08, 2025 7:23 pm so this is the protected version.
Shielded version is shown in the photo just posted. Those are the ones I use for my 45xp and 85.
