newby question
a1welding
newby question
Post by a1welding »
Good morning! I recently purchased a used spark robotic XR84 table and Im pretty happy with it. I had a quick question about indicating corners of a sheet on the table if its not square to the machine using myplasm thanks
Re: newby question
You should be able to measure from the metals edge and the rail you want to be parallel to, so both ends are the same distance from the rail.
a1welding
Re: newby question
Post by a1welding »
yes thats what ive been doing I was more so looking for an option if i load a heavy plate on the machine and im by myself it would be helpful to indicate each corner with the torch.
AREA
Re: newby question
Post by AREA »
I made up physical stops on my table and bump the material into them. If it's heavy material and I am by myself a pry bar is all I need to shimmy the material to the stops.
DIY 2x2 table
68rscamaro
Re: newby question
Post by 68rscamaro »
Myplasm doesn't have any type of skew adjustment that I know of. You have to square the plate manually.
tcaudle
Re: newby question
Post by tcaudle »
The other question is: why do you need the perfectly square to the rails ? If you are trying to use the edge of the material as one edge of a part, you are in for some headaches.Even cutting real close to an edge (or any void ) will cause problems with a THC
