Duck Hunter
Duck Hunter
I have weak drawing skills and rely heavily on this site to find cool things to cut. Seeing all the great shared designs I am going to make a good effort to learn a few things and try to put a duck hunting scene together. I have limited time and this stuff is time consuming for me so it may take a while but I have the first part started, Here is the hunter for my scene. Going to draw some ducks next. Will post all of these then put them all together, hope someone else can use these.
Re: Duck Hunter
Thanks for sharing! Looking forward to what you come up with!
Re: Duck Hunter
Cuttinparts - You're off to a great start! What drawing program are you using?
I will look forward to seeing your ducks and how you put it all together.
Re: Duck Hunter
Thanks guys!
David, I am using CorelDraw and I just finished the ducks last night. I will get them posted here shortly.
Re: Duck Hunter
Here are the ducks I just finished up. Not sure what I will do next but liley some kind of background image to help hold all this together and go from there. Suggestions welcome!
Re: Duck Hunter
Cuttinparts - these look great!
I will look forward to seeing what you come up with using your duck hunter and ducks.
Re: Duck Hunter
Thanks David. It is an auto trace from a photo with some manual cleanup to reduce the node count.
Re: Duck Hunter
Finally finished this one off for a buddy of mine in Arkansas who's big into duck hunting. Going to be around 24" wide and 17" tall. Hope to cut it this week.
Re: Duck Hunter
Very cool! I think you did a great job and it turned out very nice. Well done and thanks for sharing it
Re: Duck Hunter
Very nicely done! I will look forward to seeing how it turns out when you get it cut.
Re: Duck Hunter
Looks great, thanks for sharing. Would be cool to make one for other states. Would you mind if I use the components from your design to do that?
DIY 2x2 table
Everlast 82i
Everlast 82i
