hydraulic g clamp, lowrider frames
4130metalworks
Post by 4130metalworks »
This is my file for making a g clamp with 5mm mild steel and cheap vevor 12 ton porter power. It's very handy for pressing in pins and bushes or bending metal which is the primary reason I made and sold them. We use the clamps for shaping the metal reinforcements on lowrider frames, traditionally hammers and standard g clamps were used with varied success.
The only downside to the design is its weight, after a full day of lugging and manipulating the clamp gets mighty heavy! My next step will be to hollow out the centre plates for lightness and hopefully still retain the rigidity. I have included the instructions when we sell them to customers but if anyone has questions please ask away
It's definitely worth while buying the foot operated air/hydraulic pump so you have 2 hands free. Also we have done plenty destructive testing so you can rest easy
The porter power is held on with a section of hollow bar that's bored out and threaded to suit, or alternatively most porter power kits come with a nut and that could be welded to a short section of pipe (just alter the hole size to suit)
If anyone alters or has ideas on improvements I would love to see them.
Thanks for looking
ALSO PLEASE CHECK THE SLOT AND TAB TOLERANCES, YOUR PLASMA MIGHT NEED BIGGER SPACING
hydraulic c clamp v3.dxf
wrappy instructions.docx
AREA
Re: hydraulic g clamp, lowrider frames
Post by AREA »
Looks pretty cool but I have no idea what it does! Checked out your docx instructions in hopes of figuring it out before asking whats it for and looking like an idiot :HaHa I am curious if you have a video of this being used
DIY 2x2 table
Everlast 82i
djreiswig
Post by djreiswig »
Looks like a c press using a porta power ram.
4130metalworks
Yes it's just a stronger g clamp using a porter power
I didn't have any up to date pictures so this is when I was testing the prototype
AREA
Post by AREA »
Ah I see, should have been able to figure that out on my own...duh I think the "lowrider frames" in the title threw me off. Super useful looking tool! Thanks again for posting this!
DIY 2x2 table
Everlast 82i
hardworker
Post by hardworker »
awesome share! this will come in handy in the fab shop, thanks
One thing for sure having a CNC plasma table enables you to build your own custom tools. Moving from idea to drawing then cutting parts to using it on other projects. :Like :Like :Like
I need to make one! Thanks for sharing your great idea!
That's pretty slick, many times in the past I could have used this. Thanks for sharing, will bookmark this for next time I need one :Like
