2d to 3d conversion
AutoCAD and Fusion 360 related questions, tips and topics can be posted here
ruralfencer
2d to 3d conversion
Post by ruralfencer »
hi guys,
i was wondering if someone might be able to convert a 2d dxf to a 3d fusion drawing for me to show a customer.
I have been trying to teach myself as i go but I'm struggling with time.
Appreciate your help.
Mick
Screenshot 2024-09-11 160726.png (14.22 KiB) Viewed 9149 times
Mick
Owner/ operator
MJT rural Contracting
Weldclass t1200
Hypertherm Pwermax 45XP
Joe Jones
Re: 2d to 3d conversion
Post by Joe Jones »
I do not know Fusion 360 well enough YET, to do this for you. Someone else surely can though.
(14) X-TOOL LASERS
50 Watt GALVO fiber
(2) X-TOOL Apparel Printers
(2) XTOOL MetalFab Machines
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Grizzly G0792 - Roll Bender
Langmuir MR-1 CNC Mill
sonbakler
Post by sonbakler »
Hey Mick, are you able to post your 2d dxf designs and I can take a stab at it for you?
ruralfencer wrote: Tue Sep 10, 2024 8:34 pm hi guys,
Mick
Please post your dxf files.
What format do you want the files in?
ruralfencer
adbuch wrote: Wed Sep 11, 2024 5:32 pm
David I have sent you a PM.
Mick
Mick
Owner/ operator
Weldclass t1200
ruralfencer wrote: Wed Sep 11, 2024 10:36 pm
Mick
PM received.
ruralfencer wrote: Wed Sep 11, 2024 7:38 pm Hi David,
here is the file. it is a square firepit, so I'd like to show the customer the image all put together.
It will be made from 3mm sheet.
Cheers Mick
dxf file image.jpg (53.97 KiB) Viewed 9106 times
firepit 3d view 1.jpg (53.96 KiB) Viewed 9104 times
firepit 3d view 2.jpg (46.84 KiB) Viewed 9104 times
firepit 3d view 4.jpg (52.54 KiB) Viewed 9104 times
fire pit with cows.stl
(3.28 MiB) Downloaded 195 times
https://drive.google.com/file/d/1Lkomti ... sp=sharing
For those just starting out with Fusion 360 - I highly recommend the Fusion 360 tutorial lessons by Arnold Rowntree.
https://www.youtube.com/@ArnoldRowntree ... /playlists
ruralfencer
Thank you so much David.
I was working my way through Fusion and this is how far i got.
Thanks again. I'll have a look at those tutorials
Mick
Owner/ operator
Weldclass t1200
Screenshot 2024-09-12 203434.jpg (31.91 KiB) Viewed 9096 times
ruralfencer
That was extruded. I was able to work out extrusion with taper and create shell but that's a far as I got
Mick
Owner/ operator
Weldclass t1200
ruralfencer wrote: Thu Sep 12, 2024 4:18 pm That was extruded. I was able to work out extrusion with taper and create shell but that's a far as I got
Post a screen shot of your Fusion 360 drawing page for your part so I can see exactly what you mean.
ruralfencer
adbuch wrote: Thu Sep 12, 2024 6:53 pm
I have it worked out now thank you David
Mick
Owner/ operator
Weldclass t1200
Thanks for the tip! I had not used the tapered extrusion before - but if you can calculate the correct angles it works great! This one is not the correct dimension - but I was just trying out the tapered extrusion. I probably shouldn't have created a single body, as when I did the "Shell" operation it took out the floor where the holes would go. To me the hardest part is getting the imported dxf of the horse and cows in the correct location on the side of the fire pit. I did discover that if I figure out where to put a reference point on the sketch, then that makes it easy to move/copy from point to point.
ruralfencer
I drew the bottom plate first then taper extruded up and down, then created the shells. I already had the angles from the original 2d Qcad drawing. Not sure if that's the right process but it worked for me.
I have the profile in another dxf that i imported and dragged close to where i wanted it and extruded that, again I'm not sure if that's the right process however it got the job done.
Mick
Mick
Owner/ operator
Weldclass t1200
ruralfencer
This is my finished result minus the bend relief slots
Screenshot 2024-09-14 180139.png (107.73 KiB) Viewed 9041 times
Mick
Owner/ operator
Weldclass t1200
ruralfencer wrote: Sat Sep 14, 2024 4:02 am This is my finished result minus the bend relief slots
This looks fantastic!! Thanks for your tip on the tapered extrude operation.
Yes - it goes pretty quick if you only have to taper extrude and shell. The dxf profile is what takes all the time and causes me problems with Fusion 360 hanging or shutting down. I'll bet those with the paid subscriptions get to run on a better server with much faster processing.
It almost makes me want to go back to SolidWorks, which I have a perpetual license for and does not depend on the internet. But Fusion 360 is so much simpler to use to accomplish the same things, plus it will export the solid model for 3D printing - which SolidWorks won't do by itself.
Update: I discovered that Fusion 360 on my computer was set to work offline. I think this happened last weekend when they said they would be offline for maintenance. Somehow my setting never went back to Working Online. So now it seems to be working with the imported dxf just fine. That's a relief - I really wasn't looking forward to revisiting Solid Works.
ruralfencer wrote: Sat Sep 14, 2024 4:00 am I drew the bottom plate first then taper extruded up and down, then created the shells. I already had the angles from the original 2d Qcad drawing. Not sure if that's the right process but it worked for me.
Mick
:Like :Like :Like
ruralfencer
I have become proficient with Qcad but sometimes i want to give customers a look at the image in 3d so they can get a better understanding of the finished product.
Unlike us we can visualize the finished product.
At the end of the day, it is another tool at our disposal to get ahead of the competition and something I need to be able to do for myself.
Mick
Owner/ operator
Weldclass t1200
ruralfencer wrote: Sat Sep 14, 2024 4:59 am I have become proficient with Qcad but sometimes i want to give customers a look at the image in 3d so they can get a better understanding of the finished product.
:Like :Like :Like
Very much agreed! The more tools the better. As Tom has said in the past, it if quite often a combination of 2 or 3 or more programs to achieve the final result. No single program that I am aware of can do it all.
Return to “Fusion 360 & AutoCAD Forum”
