HELP WANTED
Ricky4x4
HELP WANTED
Post by Ricky4x4 »
HI GUYS I WANT TO CONVERT A PICTURE OF ONE OF MY FRIENDS CAR WHO JUST PASSED AWAY INTO A DXF FILE. ANY HELP WOULD BE APPRECIATED
Ricky4x4
Re: HELP WANTED
Post by Ricky4x4 »
Ricky4x4
Re: HELP WANTED
Post by Ricky4x4 »
Joe Jones
Re: HELP WANTED
Post by Joe Jones »
I normally jump onto requests to draw files, but right now I have enough to keep me busy all day long. When do you need this file? A day? A week? Anytime?
(14) X-TOOL LASERS
50 Watt GALVO fiber
(2) X-TOOL Apparel Printers
(2) XTOOL MetalFab Machines
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Grizzly G0792 - Roll Bender
Langmuir MR-1 CNC Mill
sonbakler
Re: HELP WANTED
Post by sonbakler »
Check this topic out, would give you a great start and save a lot of time viewtopic.php?p=200863#p200863
ben de lappe
Re: HELP WANTED
Post by ben de lappe »
Joe Jones wrote: Wed Jun 05, 2024 8:29 am I normally jump onto requests to draw files, but right now I have enough to keep me busy all day long.
That's my issue as well. I love to help but being so far behind in my drawings already just don't have the time unless it's something super easy to me. This one would take me a considerable amount of time.
To the OP - The first step is to determine what size you'd like this piece to be.
jmersereau
Re: HELP WANTED
Post by jmersereau »
Here is a quick first attempt at capturing the image, it needs a lot of cleaning up and bridging...
First Attempt.dxf
I will try to work on this more a bit later.
Jim
PrimeWeld CUT60
Langmuir CrossFire Pro
Re: HELP WANTED
jmersereau wrote: Wed Jun 05, 2024 11:51 am Here is a quick first attempt at capturing the image, it needs a lot of cleaning up and bridging...
First Attempt.dxf
Jim
Jim - this looks good! Is this a LightBurn auto trace? If so, could you please screen shot your LigntBurn auto trace window so I can see exactly which settings you are using.
jmersereau
Re: HELP WANTED
adbuch wrote: Wed Jun 05, 2024 12:57 pm
David, thanks! Very quick, less than 5 minutes... I used VECTOR Q on my iPad first with the "INK" filter and then a simple trace in LightBurn with the standard defaults. The only thing I changed is that the eyes didn't get picked up so I added those in LB as well. I think that I learned the Vector Q trick from you, or someone else, on this forum.
Jim
PrimeWeld CUT60
Re: HELP WANTED
Ok - good to know. I do use VectorQ for some projects, and usually followed by additional editing with Inkscape.
Thanks!!
Re: HELP WANTED
Re: HELP WANTED
Re: HELP WANTED
Ricky4x4
Re: HELP WANTED
Post by Ricky4x4 »
Joe Jones wrote: Wed Jun 05, 2024 8:29 am I normally jump onto requests to draw files, but right now I have enough to keep me busy all day long. When do you need this file? A day? A week? Anytime?
anytime is fine I appreciate the help
jmersereau
Re: HELP WANTED
What is the desired size of final product?
What is your normal kerf width?
What material are you cutting this out of?
Here is a cleaned up version that still needs work but not without your answers to the above questions.
Rock Crawler v2.dxf
Jim
PrimeWeld CUT60
Re: HELP WANTED
This is what it would look like when cut.
