HELP please.
I have 4 HB808C hybrid closed loop stepper motor drivers and I want to connect these to the E-stop input on the Myplasm controller.
When I fault a drive and measure the ALM+ and ALM- outputs I get no voltage reading etc.
Here is the pic from the HB808C manual.
What I want to do is to run all of the alarm outputs in series and trigger a relay with a dry contact if any of these fault for any reason that will stop the program. Can anyone help me with how this wiring would be accomplished please.
Driver alarm output to Myplasm input
Re: Driver alarm output to Myplasm input
I am guessing the alarm output from the HB808C goes low to ground when an alarm is triggered. I am not an electronics guy but you may be able to do this with a 5vdc relay. Will take some experimentation I am sure but should be easily done. Hopefully someone else here with more electronics experience can help.
