2 stage issues. Help!!!
Lukemetalworx
Post by Lukemetalworx »
Alright guys, I’m still pretty new to adding powder coating to our business. The single stage is going pretty good, but 2 stage with a chrome base is kickin my butt. I will post my results and feel free to tear me apart please. One picture of hows it’s suppose to look and one of mine. Thanks guys
kicktillmonday
Re: 2 stage issues. Help!!!
Post by kicktillmonday »
It looks like you may be laying on too much powder on stage 2.
DIY 4x8 table
Powermax 65
Lukemetalworx
Too much?..really. And that’s y it’s hardly sticking or having any color to it?
kicktillmonday
Well it's pretty hard to tell from the image but it appeared as though powder was pooling near the edges. Maybe that's not the case and it just looks that way in the pic. Since you have this there in front of you, do the edges look dramatically different in thickness and color from the rest of the part or is it just me?
DIY 4x8 table
Powermax 65
Lukemetalworx
kicktillmonday wrote: Thu Apr 11, 2024 11:08 am Well it's pretty hard to tell from the image but it appeared as though powder was pooling near the edges. Maybe that's not the case and it just looks that way in the pic. Since you have this there in front of you, do the edges look dramatically different in thickness and color from the rest of the part or is it just me?
Yea both pieces I’ve done look like that
With no real color to the test peice
Lukemetalworx
Another example
kicktillmonday
Is your heat accurate and at the correct temp for the type of powder your using?
DIY 4x8 table
Powermax 65
Lukemetalworx
kicktillmonday wrote: Thu Apr 11, 2024 11:37 am Is your heat accurate and at the correct temp for the type of powder your using?
I believe so. Both the pink and teal are 375 for 10 mins. And the chrome is fully cured as the base coat
Lukemetalworx
Any other ideas from anyone? I’m gonna spray a couple more test pieces.
05Duramax
Post by 05Duramax »
I find it strange that out outer edges look like a nicer finish and a more brilliant color. I suspect the outer edges get up to temp faster which could be the reason for this. Maybe you just need to get the entire piece hotter and faster for better flow out and gloss on the entire part.
Awesome
Post by Awesome »
Are you just putting it in the oven for 10 minutes, or are you putting it in for 10 minutes AFTER flow-out has been achieved? There's a huge difference.
GoodB0Y
Post by GoodB0Y »
Just thought I'd add to this... I know it's an old thread
I'm far from a powder coating expert lol
It's difficult to see exactly what's going on in the pictures but it looks like uneven powder and under cured to me. I suspect back ionization, bad grounding and too low temperature or incomplete cure schedule.
The cure schedule for powder coating starts when the part gets to the recommend temperature not the oven temperature and not after flow out. Flow out is not an indication of the part being at the cure temp. You need to have an irgun to check. Once you get the part to the cure temp start your timer. This can be a significant amount of time depending on the density of the part and the capability of the oven.
Second coats require good grounding and lower settings kv ua, lower air pressure. And sometimes more powder flow.
GoodB0Y
Post by GoodB0Y »
Now that I think of it... Chrome needs to be fully cured or the colour ends up not being right. I've never seen it but maybe that's what the pictures show... Improper or under cured chrome
Return to “Powder Coat”
