How can I cut this text
saftaiiustin
Post by saftaiiustin »
Hello,
I''m trying to figure out how to draw theese letters so they are not falling when processing.
I'f anyone has any ideea, unfortunately I can't change the logo design. Maybe scaling the text bigger and adding help lines?
Thank you,
Iustin
Re: How can I cut this text
The cursive "Classic" letters could be easily connected together and attached to the outer ring by extending the line on each side to connect the text to the outer ring. As for the "DMI GARAGE" I am not sure there is much you can do aside from a straight line at the bottom of the letters connecting them all together and to the ring. Since you cannot change the logo I would say this is better completed as a 2 layer sign and you could affix the individual letters to the backing plate.
saftaiiustin
Check this solution i found
Couldn't think of something better
Very nice, looks awesome. If the customer is cool with that I don't see any better way :Like :Like
