Hi all,
Anyone with a Go Torch and advanced machine control, what is your method of indexing a sheet while design edge puts the sheet in the
0 and 90 direction. And the Go Torch is open on the left and right end, 0 180 and 0 direction. I don't know how to change the sheet display
in design edge. Maybe someone has a solution.
CNC_rowdy
Go Torch Indexing
- CNC_rowdy
Go Torch Indexing
Go Torch 2x2 Table
Advanced Design Edge, Machine Control, Height Control
Snap & Cut Torch Holder
Hypertherm XP 45 Plasma Cutter & Machine Torch
Re: Go Torch Indexing
- Joe Jones
Why not just rotate the design 90 degrees in the software?
(14) X-TOOL LASERS
50 Watt GALVO fiber
(2) X-TOOL Apparel Printers
(2) XTOOL MetalFab Machines
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Grizzly G0792 - Roll Bender
Langmuir MR-1 CNC Mill
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
- rdj357
Because the GoTorch just sits on the material (unless you've made a table as many of us have) they don't see it as an issue that, as you say, the GoTorch indexes in the wrong direction.
You could, in theory, do what Joe suggests and create your indexed cut paths with the design going across the 2 tables sideways and then rotate it. Draw a 24" square around each section so it's easier to move it around with node point snaps. You should probably put the table size back to 2'x2' before moving things just to simplify the view while doing this. Then cut the first table section, slide the material up, move the second table area onto the table and line up the material to the cut paths and then cut the second section.
As David said, having customizable size lets you set the table axes orientation to match the controller orientation which would let you do this without moving anything around.
Robert Johnson
PlasmaCAM GURU & Instructor
- Joe Jones
Right. He did not indicate that he built a table for the Go Torch, but I assumed he did, since he could not index the material on the axis he desired.rdj357 wrote: Mon Mar 11, 2024 7:33 pm Because the GoTorch just sits on the material (unless you've made a table as many of us have) they don't see it as an issue that, as you say, the GoTorch indexes in the wrong direction.
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
- CNC_rowdy
Yes all. in reply, I did build a table for the Go Torch, so it is mounted permanently. I have indexed sheets from left and the right side, but not top to bottom as the machine option shows. I do not work with the machine enough to justify getting the customizable size option. I know a lot of you run your machines everyday, but this is just a hobby to me. I was just asking questions, so any replies I get back are great.
Thanks all,
CNC_rowdy
Thanks all,
CNC_rowdy
Go Torch 2x2 Table
Hobby guy here as well! I use my table mainly for Christmas gifts for family members. Let us know how you make out with your project, and perhaps share a few photos of your finished result.CNC_rowdy wrote: Tue Mar 12, 2024 6:17 am Yes all. in reply, I did build a table for the Go Torch, so it is mounted permanently. I have indexed sheets from left and the right side, but not top to bottom as the machine option shows. I do not work with the machine enough to justify getting the customizable size option. I know a lot of you run your machines everyday, but this is just a hobby to me. I was just asking questions, so any replies I get back are great.
Thanks all,
CNC_rowdy
- CNC_rowdy
I will David, I will post some goodies here for all to look at when I can.
CNC_rowdy
CNC_rowdy
Go Torch 2x2 Table
