Resizing all holes in a drawing?
Joe Jones
Post by Joe Jones »
The question: Can you resize all of the holes in a drawing simultaneously?
http://youtu.be/Q-3FetqIKC8?si=cUnNv-JMy6ZdeaQY
(14) X-TOOL LASERS
50 Watt GALVO fiber
(2) X-TOOL Apparel Printers
(2) XTOOL MetalFab Machines
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
MakerBOT Z-18 3D Printer
Grizzly G0792 - Roll Bender
Langmuir MR-1 CNC Mill
Joe Jones
Re: Resizing all holes in a drawing?
Post by Joe Jones »
Actually, I forgot about the ability to convert CUT PATHS to open and closed paths!
http://youtu.be/jx6e4h-oSYY?si=-k_U1Cw-MxBnjkpB
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
rdj357
Post by rdj357 »
As I said over on the owner community - well done. That's a great, outside the box trick! It will be less handy if you have many other holes in the drawing unless you spend some time grouping and moving things around but definitely something to tuck back and analyze which method would be faster, offset or this!
Robert Johnson
PlasmaCAM GURU & Instructor
Joe Jones
Post by Joe Jones »
rdj357 wrote: Sat Mar 09, 2024 10:28 am As I said over on the owner community - well done. That's a great, outside the box trick! It will be less handy if you have many other holes in the drawing unless you spend some time grouping and moving things around but definitely something to tuck back and analyze which method would be faster, offset or this!
You are correct, Robert! If there are many holes of different sizes, you would have to GROUP the holes of the same size (using VIEW>SELECT>) in order to only change THOSE holes to a new size. Otherwise you would offset ALL holes (and other shapes, squares, stars, triangles, etc.) using the process in the video. Good call!
My assumption was that the holes were all for pop rivets, as the OP stated, so the process would work for THAT. But one must be careful not to resize ALL closed paths in a drawing.
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
Joe Jones
Post by Joe Jones »
A final comment on the process of resizing holes in a drawing...
http://youtu.be/WBRibEwraM0?si=sze8nZuZxGKr_X2Y
(14) X-TOOL LASERS
50 Watt GALVO fiber
CreatBot D600 PRO
Fortus 400mc
BIGREP Studio Gen 2
MODIX Big Meter
