Elk camp barrel stove with plasma cut parts
Small barrel stove with plasma cut parts that can be reused if the barrel rusts or burns out over time. The tri-stand is removable and collapsable. When I fired it up to cure the paint I had a lot of smaller wood in it and it took off like a rocket but settled down to a steady burn. The curing paint smoked a bit but no smoke escapes from the stove even with the lid open. There is an ash grate inside so the bottom compartment stays cool compared to the combustion chamber. You can hold your hand under the stove at full burn with no problems. I could use this stove as a chiminea on my deck with no danger of harming the wood. Just a fun project to get rid of some barrels cluttering up the shop. The spark arresting top on the stovepipe was plasma cut also.
Re: Elk camp barrel stove with plasma cut parts
That's awesome, very nicely done!
- tnbndr
Nice design!
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
2 thumbs up on that deal.
Awesome looking stove! Well done
Tracker CNC 4x4
