beginer setting up CNC motors
I am building a CNC plasma and have ordered my drivers, motors, breakout board and downloaded Mach3. I am bench testing everything but my motors are not turning. I have my first motor wired to the breakout board to the x and I'm using the keypad number 6 and 4 to make the motor turn but nothing happens. I have double checked the wiring and it is correct. Does anybody have any suggestions?
Re: beginer setting up CNC motors
Typically the breakout board sends the signals to the drivers and the drivers turn the motors but you are stating that you have your motor wired to the breakout board. Did you connect your motor to your breakout board?
DIY 4x8 table
Powermax 65
Powermax 65
Normally Mach 3 use the arrow keys for moving the X and Y motors and the page up and down for the Z. Not the key pad with the numbers.
I have motor wired to the driver and the driver is wired to the breakout board. I went over and over the wiring and a friend told me to just disconnect it all and re connect it. That did it. Must have not had a good connection somewhere because it is working now. Thanks, I'm learning all this for the first time. I feel stupid but I have tenacity so I eventually get it. Thanks again.
Don't feel stupid, mistakes are part of learning, and having a second set of eyes always helps. Not many can say I turned on a new thing in my life and everything worked great.
Awesome, glad you have it working. Often it something as simple as the wire being on the wrong side of the screw terminal or not stripped far enough back. Curious how your project works out for you so post your progress if you can and pics are always great.
DIY 4x8 table
Powermax 65
Powermax 65
