Powermax 125 error code 0-12-2
Discussion on 0-30 fault codes
EPS
Post by EPS »
Info tells me my output pressure is too high. What does that mean and how do I fix? Torch will cut for a few seonds and then stop and just blow air. 0-12-2 is the code i am getting. Air guage says I have 110 psi coming from air line.
Thank you!
weldguy
Re: Powermax 125 error code 0-12-2
Post by weldguy »
Not sure where your air guage is located but on the inlet at the back of the plasma is best so you can watch for any pressure drops or spikes. Sounds like you may have a different issue than that but still a good idea. Nor sure if you have seen this yet https://www.hypertherm.com/en-US/resour ... ect%20flow. but check it out and if you can find a service manual for the 125 online you can do some testing and narrow it down.
Return to “0-12 Fault Code”
