Lead in coming in on wrong side? What's causing this?
Tristar500
Post by Tristar500 »
I set up a .3 lead in arc but was surprised to find the lead in was on the opposite side of the interior cut.
I'm pretty new to sheetcam and wading my way to progress.
Thanks for any help!
kicktillmonday
Re: Lead in coming in on wrong side? What's causing this?
Post by kicktillmonday »
A loooong time ago I had this happem, can't remember exactly what the issue was but I think for me the outer profile was not closed so it didn;t see the inner profiles as inner profiles. Can you post your file?
DIY 4x8 table
Powermax 65
Tristar500
I get a message telling me I'm not a contributing member and want's to charge me to have more access.
I attached a pic to the original post for clarity but it looks like that didn't upload either.
Ugh!
Thanks for trying!
I'll look and see if the outside path was connected or not. I think it should be the hole pattern was highlighted in yellow an the outline in red.
If I understand correctly that is the way it's supposed to be.
I got no indication on the screen in SheetCam as it didn't show the lead in. I thought it was strange and now it's more or a mystery....
Tristar500
Sorry, looks like pic is now showing up.
I still don't think I can upload the dxf without paying these folks?
SegoMan DeSigns
Post by SegoMan DeSigns »
Once you have your drawing loaded
Under the mode tab / edit contours did you separate inside vs outside cuts and name them accordingly?
Then once that was established under operations did you set up an inside offset to the corresponding layer name for the inside cuts?
Then again under operation select outside offset assigned to the outside layer name?
Hope that makes sense..
Tristar500
Thannks, That fixed it. I had not separated the inner and outer lines and did not use an offset. This was just a test part on a new machine so I didn't worry too much about the particulars.
I also had "show toolpaths" turned off which hid my mistakes. Had I seen the toolpath I would have immediately noticed that something was wonky.
Learning, learning,,,,, :Like
Thanks Again! :Yay
SegoMan DeSigns
Good Deal..
The no offset & no lead in works great for bend lines or regular line only cuts. Offsets are based on the Kerf widths as outlined in your tool sets.
A great metal / $$ saver feature is once the parts parameters has been set is to click on the Mode / Simulation tab and watch the tool paths run.
TJS
Post by TJS »
Also for holes you want the lead in perpendicular and I make it about a little less than the radius. No lead out on holes and watch the delay at end (make it less than what it is) to minimize the divot. Also slow down 60% speed of book speed. Anything thicker than .250" I add a little bit of overcut.
The simulation is good too. I also use @acourtjesters Pen tool. Total saver of material and in the end a time saver.
T.J.
Tristar500 wrote: Tue May 23, 2023 10:28 pm Sorry, looks like pic is now showing up.
Tristar500 - Much great information to be had here, including a wealth of nice cut files. I would encourage you to become a contributing member so that you can take advantage of all of this. At only 20 bucks I think it's a real bargain.
Tristar500
adbuch wrote: Wed May 24, 2023 9:08 pm
Done!
I'm now a contributing member. Yes, I agree. I think it's worth it. Thanks! :Yay
Return to “SheetCam”
