Quick change torch holder
kn612
Post by kn612 »
Quick and easy torch holder. Still need to make a bracket that holds the unused torch on the x axis. 1 3/8 split lock collar. The magnets are 3/4" diameter. #8 socket head machine screws help line the torch in the mount. Undersized all bolt holes so they could be cleaned up with a drill, any holes under 1/4" diameter my machine doesn't do so well. I got the idea from Maverickcnc plasma tables
torchmount.dxf
DieselFumes
Re: Quick change torch holder
Post by DieselFumes »
Brilliant! Haven't seen anything like that before. I only have one torch but if I had to change it out often I would use your design, it's awesome. Thanks for sharing.
Tracker CNC 4x4
kn612
Post by kn612 »
If I had a 3d printer I would rather make one like this, viewtopic.php?f=3&t=30742&p=186559#p186559
Might re design mine for a few switches to stop torch motion in a breakaway. Right now the z floating switch acts as an estop so motion atleast stops if the torch dives.
I don't like the breakaway mounts that allow the torch to fall all the way off and the capture ones don't allow you to switch torches.
Great job kn612!
Might have to think about making one!
whizbang
Post by whizbang »
Really nice! I am interested in retrofitting to be able to run a gas torch. I may be using the wrong words because I'm not finding alot of documentation for DIY'ers. If I can figure it our I am definently going to cut this out.
That is a pretty slick setup for quickly changing from gas to electric torch. Thanks for sharing your design with us.
Farmer850
Post by Farmer850 »
I had been pondering the maveric design when I recently came across your post. Now more motivated to proceed.
Question - did you need to shim the magnets to get your torch alignment correct? I see McMaster-Carr has ring
shims available from .001" on up.
Thanks.
kn612
Post by kn612 »
Farmer850 wrote: Tue Dec 03, 2024 12:29 pm I had been pondering the maveric design when I recently came across your post. Now more motivated to proceed.
Thanks.
No, shims aren't necessary. Depends how square you assemble it.
