PLATE ROLLER
PLATE ROLLER
WHERE COULD FIND DRAWING FOR PLATE ROLLER , NEED ROLL FIREPIT RINGS
- Joe Jones
Re: PLATE ROLLER
You want to BUILD a plate roller instead of buying one that is already engineered and designed to handle a certain level of material? I am all for taking on projects, but I would rather buy one than build one.
Re: PLATE ROLLER
How wide are the rings, and what thickness material? Here is something that may help you.plasmalady wrote: Sat Feb 25, 2023 6:24 pm WHERE COULD FIND DRAWING FOR PLATE ROLLER , NEED ROLL FIREPIT RINGS
https://www.plasmaspider.com/viewtopic.php?t=4477
Re: PLATE ROLLER
https://www.etsy.com/listing/878926630/ ... -a-36-inch
This is dxf files and plans for a 36 inch plate roller for using cnc plasma or laser.
"YOU WILL NEED TO FIND SOME 3.5 INCH SCHEDUAL 40 PIPE IT WILL BE 4 INCHES IN DIAMETER OR FIND SOME 4 INCH TUBE AT LEAST CLOSE TO 1/4 THICK''.
You will need a cad program to make some spacers that need to be very close to fit into the pipe.
It will roll 9 inches of 1/4 inch and wider of thinner material.
all the parts are listed with links and all the materials.
you will need a welder that can weld 1/4 inch steel.
A drill press or drill that can drill a 1.5 hole in aluminum 1.5 inches deep.
Some parts like the acme nut/coupling and the 2.5 solid aluminum can be found cheaper on ebay but they keep changing the listing so I put some links that shouldnt go away from companies.
Re: PLATE ROLLER
Nice. I am looking at buying a ring roller from a guy on YouTube. He sells them for making bands on bbq smokers doors.
Re: PLATE ROLLER
1/8" thick mild steel plate 22" wide need to roll
- Joe Jones
Re: PLATE ROLLER
It would be cheaper to find a metal fab shop in your area that already has a plate roller with that capacity and negotiate a price to roll your firepits for you. A machine capable of doing what you want to do is many thousands of dollars.
Re: PLATE ROLLER
closest fab shop is 3 hrs away
- Joe Jones
Re: PLATE ROLLER
Do you want flat blanks rolled, to cut out designs from after they are rolled, or do you want to cut the art out of the flat panels and then roll them? Where are you located?
- Joe Jones
Re: PLATE ROLLER
It is possible to roll 1/8" plate 24" wide using smaller rollers if you HEAT the metal during the rolling process. There is no law that says plate must be rolled STONE COLD. A bank of rosebud torch heads that the metal will pass over (or under) as the plate is rolled will allow smaller rollers to roll thicker and wider plates. It would most likely need to be a homemade roller, with a bank of acetylene rosebuds that would soften the metal before it passes through the rollers. Of course heave gloves would be used to handle the finished piece!
Re: PLATE ROLLER
This one should do it for you. These look like nice plans.
Re: PLATE ROLLER
If you are doing a bunch of them and just need the blanks rolled, then it may very well be worth you time to take that 3 hr. drive. If you've got the funds there are most likely ready built models (new or used) available as well.
