The price is not bad for both controller board and THC board. What type of software can be used on Linux based os? Do I create and edit my cut files in a Windows environment then convert and or transfer to the Linux CNC?Rodw wrote: ↑Mon Jan 30, 2023 3:40 pm
You have a very closed mind so its probably best you stick with Windows software. Just be aware external THC's cannot compete with ones embedded n the motion controller which is how linuxcnc works. That is because the motion controller knows everything going on and extenral THC's fly blind.
Mesa is a long standing company specialising in motion hardware, particularly for linuxcnc. The owner is a very active member of the linuxcnc forum and tirelessly offers support to users and is on hand to answer any questions about his hardware. Thousands of machines use Mesa hardware. Hundreds of rtrofitters breathe new life into old iron machines with mesa and linuxcnc. Tormach uses linuxcnc and mesa cards and CommandCNC also uses mesa hardware with their linuxcnc system.
For Plasma you need a 7i96s and a THCAD-2 as I said before. Building a plasma config using this hardware is supported by pncconf, the mesa configuration tool bundled with linuxcnc.
My plasma cutter TD 60i has a built in voltage divider machine board that allows me to select the divided arc voltage as well as iirc collision detection with Ohmic sensing. The TD 60i uses both non shielded and shielded consumables for Ohmic sensing. Once again iirc the non shielded consumables use a wire from the pip to sense Ohmictouch and the shielded consumables require the external wire to clip to the Ohmic clip. This is where I get confused. If I use shielded or non shielded, does my machine still only use two signal wires out to the THC unit. Trying to understand how it works.
Then with that in mind how does that work with the THCAD-2
