Awesome Plasma Table Sharpie Pen Holder ... FROM???
Topics related to pen markers, remote controls, drawing tablets, & other plasma table related accessories
Joe Jones
Post by Joe Jones »
I must apologize for my failing memory. I know I purchased this totally awesome pen holder from someone on Plasmaspider, but I cannot remember WHO made it and sold it to me. I also cannot remember what I paid for it. :Sad
My memory really IS that bad. I want to point other people to this person, so more of these can be sold! Respond here, so other people can also get the information I seem to have lost, and may also want to order one. I want to pass this along on various Facebook group posts, etc. This thing works great!
TJS
Re: Awesome Sharpie Pen Holder ... FROM???
Post by TJS »
Here is one I got from the great Acourtjester. Note if you are using Command CNC use the Contour Operation in SHeetcam. So simple.
Joe Jones
Post by Joe Jones »
That is who it was! aCourtJester. I would like to refer him to others who are seeking a way to use their cnc tables for drawing and tracing functions.
TJS
Post by TJS »
It works great once I used the contour tool. It really saves on material on design changes or fit up changes. For bracketry and parts I used to cut out super thin junk I had and then would perform a fit up and then cut the real part out of the required material. I now skip this money wasting step.
T.J.
Plasma-art
Post by Plasma-art »
TJS wrote: Thu Dec 01, 2022 1:02 pmIt really saves on material on design changes or fit up changes.
You cut it out as a paper template to check for fit?
TJS
Post by TJS »
Plasma-art wrote: Thu Dec 01, 2022 1:35 pm
Yes. Right now paper/manila folders are cheaper than steel and alum. For now at least.
Joe Jones
Post by Joe Jones »
Get the brown hardboard (1/8" pegboard without the holes) from the big box stores. They are still cheap, and easy to cut for this fitting process.
TJS
Post by TJS »
Thanks for the tip Joe. @acourtjester
Happy to help I can print up as many as needed, $30 shipped in conus, for those with 3-D printers STL file free for the asking. :Yay
TJS wrote: Thu Dec 01, 2022 12:02 pm Here is one I got from the great Acourtjester. Note if you are using Command CNC use the Contour Operation in SHeetcam. So simple.
That one works perfect. I got one from Tom a while back and a very nice tool.
tnbndr
Post by tnbndr »
Interested in how to setup and use the Contour tool in SheetCam.
I have a pen holder from someone on here, probably Tom, but never got it to work right.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
Using the pen tools and planning in SheetCam is easy. You create a new tool with a plasma base, see attached image with info.
load in a drawing and select the contour tool in the planning section, use the no offset with no lead in/outs. Use a non-Plasma post processor. no need for touch off or plasma operations. move the pen to your start location drive the pen down touching the paper and about 0.050" more. Zero out the DROs and drive the Z up off the paper and hit run. pen will move to the start location on the drawing and move the pen down touching the paper with a small amount of pressure (from the addition down position and the spring pressure. It will draw on the paper whatever you have in the in the plan, as shown in the videos. Have fun
Joe Jones
Post by Joe Jones »
I have lots of people OUTSIDE of plasmaspider asking me how to order one of these. What do I tell them?
djreiswig
Post by djreiswig »
I'd tell them to join. Why wouldn't they want to be part of this?
Joe Jones
Post by Joe Jones »
djreiswig wrote: Sun Dec 04, 2022 9:06 am I'd tell them to join. Why wouldn't they want to be part of this?
Because they do not have cnc plasma tables. They have cnc router tables, or the cnc blue diode lasers, or the CRICUT machines, or the embroidery machines, or any other machine that can use the capability of the Sharpie pen holder.
I agree with djreiswig. Tell them to join. Even if they don't do cnc plasma cutting, they must use some design software and there is a wealth of information here to share with them. Even if they are not a "contributing member", then can still read the text and send a pm to Tom to order.
Joe Jones
Post by Joe Jones »
I do not know who these people are. I have told them that I bought the pen holder from acourtjester on plasmaspider, and provided a link to this forum. I am not going to insist that they sign up, because it will raise red flags. I just thought he might have some generic means of communication that I could share.
Here is one similar they can buy on Ebay. I've sold lots of these and never had any complaints.
https://www.ebay.com/itm/125453656562
They could also message Tom thru his Youtube channel under the comments section.
https://www.youtube.com/@courtjester90/videos
tnbndr
Post by tnbndr »
Thanks Tom:
I created the Pen Tool, but the problem is that I don't have a contour option in the lower pane.
SRdesign
Post by SRdesign »
tnbndr wrote: Sun Dec 04, 2022 6:53 pm
Thanks Tom:
Another way of doing it that I found to be easy is that when you are selecting your operation, don’t select plasma. Select contour, then your default tool will be rotary tool. You don’t have to do anything else except zero your z axis to your pen holder compression.
My 4x8 Build
DIY 4x8
C&CNC Bladerunner G5
Hypertherm PM85
That is because Plasma moves up from the surface for its operations, and Routing moves below for its operations. You can assign how far it moves down to produce the marking pressure. When I use the table for drag knife operations I produce a plasma tool so I can move just past the start/stop location (over cut)to insure the cut is complete.
djreiswig
Post by djreiswig »
Thanks Tom:
I think you have to turn on the mill part of SheetCam to get those operations.
tnbndr
Re: Awesome Plasma Table Sharpie Pen Holder ... FROM???
Post by tnbndr »
I don't have Contour as a selection anywhere in any pull down menu. I do know my Sheetcam was set up by Dan at LDR so I'm sure it is a custom setup.
Maybe the pen isn't possible?
ROKCRLER
Post by ROKCRLER »
tnbndr wrote: Mon Dec 05, 2022 6:53 pm
I was having the same issues...
Click HELP, Setup Wizard, then select Rotary cutting then it will show up. I was uncluttering the panels a while ago and unchecked it and couldnt find it.. we here it is now :HaHa
On another note, i dont show any tools like Tom shows.
EDIT:
well, i didnt see tools because i hadnt created a rotary tool... made one for the EasyScriber and it showed up.
Hoping to try y'alls tips this weekend.
4x8 Dynatorch
PM85
~Mo~
Return to “Pen Markers, Remote Controls, Drawing Tablets, etc.”
