Please help Brahmans Logo
I would like some help converting the attached logo into a line drawing so i can place it on the side of a fire bucket if possible.
Mostly the brahman text but a separate image of the bull would be great.
Is there a tool to help with this?
Thank you
Thank you
Re: Please help Brahmans Logo
It would be nice if you had a higher resolution image to work with. You could use Inkscape to auto trace, and then some editing to clean up. Where did you get the original image?
Just a google search i messaged the facebook page for a logo but no reply yet
I would be tempted to use a combination of auto trace and manual tracing. What program are you planning on using to do your editing?
- Joe Jones
It can be drawn in DesignEdge and other programs, but it would take some time.
I have solid works or coraldraw at workadbuch wrote: Wed Sep 14, 2022 8:24 am I would be tempted to use a combination of auto trace and manual tracing. What program are you planning on using to do your editing?
- Joe Jones
Do you know how to use CoralDraw? That should produce the file for you just fine.
CorelDraw or Inkscape will work fine. Solidworks or Fusion 360 don't lend themselves well to this sort of work.Damo85 wrote: Wed Sep 14, 2022 3:40 pmI have solid works or coraldraw at workadbuch wrote: Wed Sep 14, 2022 8:24 am I would be tempted to use a combination of auto trace and manual tracing. What program are you planning on using to do your editing?
Kinda sorta i have tried to quick trace but get mixed results im having another go nowJoe Jones wrote: Wed Sep 14, 2022 5:34 pm Do you know how to use CoralDraw? That should produce the file for you just fine.
This is what i have for the text so far
That text looks good! What program are you using for your trace? I think I had better luck with Inkscape than CorelDraw for the auto trace.
Keep in mind that just like the Kenworth truck you cut into your fire pit a while back, this one will also need some of the letters stenciled and bridges added to the bull to keep him from falling out when cut.
Yeah i played around a bit more and got thisadbuch wrote: Thu Sep 15, 2022 2:41 am Keep in mind that just like the Kenworth truck you cut into your fire pit a while back, this one will also need some of the letters stenciled and bridges added to the bull to keep him from falling out when cut.
But now they want the letters separated which i will try tomorrow thank you for all your help
What program are you using that you show in your screen shot?
A mix between both inscap and coraldraw that image is what it looks like when i import it into libellula.wizard thats what we use to nest items on the swift cut machineadbuch wrote: Wed Sep 14, 2022 7:19 pm That text looks good! What program are you using for your trace? I think I had better luck with Inkscape than CorelDraw for the auto trace.
Here it is with the letters separated.
Oh wow thank very muchadbuch wrote: Thu Sep 15, 2022 4:06 am Here it is with the letters separated.
Whitsunday Brahmans Bull Poster with stencil letters.svg
You may also find this one useful. I have separated out the text and bull.
You are quite welcome! Happy to help. I've learned a few things here as well on this one.
Let us know how it turns out when you cut it.
I can't thank you enough you are an absolute legend.adbuch wrote: Thu Sep 15, 2022 4:32 am You may also find this one useful. I have separated out the text and bull.
Whitsunday Brahmans Bull Poster - text and bull separated.svg
You might also consider this one with the "B" stenciled vertically to match the other stencil cuts.
I also think the bottom feet on the center letters could use some adjusting so that they fit the curved shape more closely.
I did these letters by tracing manually and the resolution of the image was poor, so it was hard to get everything lined up perfectly.
It may not matter for your application, but I will see if I can align them better.
I think these look much better.
Thank you it looks good.adbuch wrote: Thu Sep 15, 2022 5:04 am I think these look much better.
Whitsunday Brahmans Bull Poster - B stenciled vertically and center letters aligned to curve.svg - image.jpg
I will post photos tomorrow when i get time to cut it out
Cheers
