Chevy Motor Mount for Run in stand
TJS
Post by TJS »
Building a run in stand and did not want to use the ugly factory to engine block mounts. So I drew these up and cut one out of this stuff first to make sure I am good. Final product will be 1/4" plate. Slices in it for bending without a brake.
These will fit any Small Block, Big Block and 6.2/6.5 diesel family as well as V-6s. NOT LS. I will upload the file soon from my other computer. Just grabbed these off my phone. The height of the ear tabs can also be adjusted to fit your needs. Such as to make the engine to sit where you want it in your hot rod or whatever.
DieselFumes
Re: Chevy Motor Mount for Run in stand
Post by DieselFumes »
Pretty slick mock up. Nice job!
Tracker CNC 4x4
Bowties for ever look great.
TJS
Post by TJS »
Here is the SVG
motormounts.svg
Joe Jones
Post by Joe Jones »
What mounts to it? The alternator?
TJS wrote: Fri Apr 15, 2022 11:28 am Building a run in stand and did not want to use the ugly factory to engine block mounts. So I drew these up and cut one out of this stuff first to make sure I am good. Final product will be 1/4" plate. Slices in it for bending without a brake.
Nice job on those motor mounts for mock-up. Obviously the thin material shown is not meant for actually supporting the engine in operation, but great for testing the fit when doing an engine conversion to fit check mounting to cross member or frame rail supports. The finished mounts from 1/4" plate should be plenty strong. I am used to using the standard mounts with rubber blocks, or the donuts on the rigid style hot rod mounts. Thanks for sharing this!
TJS
Post by TJS »
Joe Jones wrote: Fri Apr 15, 2022 12:36 pm What mounts to it? The alternator?
Joe these are engine mounts that bolt to the side of Chevy V-8 including 6.2/6.5 Diesels or V-6 blocks (NOT LS). I will be using a thicker version as a final product. These will be used for my Engine run stand which allows me to run the engine before putting it into a vehicle. Some say it is an un-necessary extra step to pre run an engine on a stand outside of the vehicle, but it really is a time saver if you find an issue (leak, gasket, etc.).
These can also be used in place of a stock chevy block to mount, to mount to the engine mount that is bolted to the subframe in a chevy vehicle. That is what the ears are for. A bolt goes thru those hose capturing a factory chevy mount (rubber and steel) that is bolted to chevy subframes. Hope this helps. I will be doing a post on my run in stand when I fully get to it.
T.J.
Joe Jones
Post by Joe Jones »
TJS wrote: Mon Apr 18, 2022 7:34 am
Ah, I didn't catch that in the previous post.
Solid engine mounts ... no shock or vibration buffer ... I remember when these were popular back in the 70s, in the days of the muscle cars. Once in a while, the engine would produce SO MUCH torque, that wall of the engine block itself would fail, having nothing to absorb the sudden forces applied to the side of the block. It is possible to make V-8 engine very powerful. I guess people still use them.
TJS
Post by TJS »
Joe Jones wrote: Mon Apr 18, 2022 10:08 am
In a stock chevy mount configuration the vibration damping is in the mount on the factory subframe where the captured bolt goes thru. No solid mounts in a stock config.
T.J.
Joe Jones
Post by Joe Jones »
TJS wrote: Mon Apr 18, 2022 10:23 am
T.J.
It has been some 40+ years since I have crawled under a car. I used to rebuild my own engines, and replace my own clutches, and do my own brakes, etc. Those days are long behind me now.
DJC
Post by DJC »
I've tried convertio to get the svg to a dxf but am struggling...anyone have this file as a dxf? Thanks-
DJC wrote: Tue Dec 17, 2024 9:53 am I've tried convertio to get the svg to a dxf but am struggling...anyone have this file as a dxf? Thanks-
Used Corel DRaw to convert it. Does this work for you?
SBC-BBC-MotorMount.dxf
DJC
Post by DJC »
That looks great! Going to try it right now, thanks!
TJS
Post by TJS »
DJC,
Post your final product if you will.
Thanks.
DJC
Post by DJC »
I will, the holes where it mounts to the block lined up well - I had to widen the rest a bit to fit over the stock mount on the frame...
Let me get back to the computer and I will try and post my revised version. Thanks!
DJC
Post by DJC »
attempt
chevy sbc to frame mount.pcm
TJS
Post by TJS »
DJC wrote: Tue Dec 17, 2024 1:31 pm I will, the holes where it mounts to the block lined up well - I had to widen the rest a bit to fit over the stock mount on the frame...
These were more designed for an engine run stand I built. Sounds like you are on track to make it work with factory clamshells on the engine cross-member.
DJC
Post by DJC »
Yes - I understood they were for a test stand, I did want to see if I could adapt them to the factory frame mount and I think I got it. You provided a good file for me to use, thanks for the good work!
tinspark
Post by tinspark »
DJC wrote: Tue Dec 17, 2024 1:48 pm Yes - I understood they were for a test stand, I did want to see if I could adapt them to the factory frame mount and I think I got it. You provided a good file for me to use, thanks for the good work!
DJC, Maybe add that file here if U can? Some other members may want to give it a whirl out of light gauge to check fit before making out of plate. What thickness is a good gauge to handle that much torque?
Also, I have found that on thicker plate (3/16" and up) the plasma notch used to bend easily usually snaps, or at least tears enough that the two parts are barely hanging on. I have been separating the two parts in CAD and just plan on welding the pieces since the torn remnants often get in the way for a clean weld fit up, easpecially since when plasma sliced at the brake, it will need to be welded out anyway.. :Like :Like
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
DJC
Post by DJC »
I will try and post the dxf., I need to relearn how to post - I don't do it very often. My test pieces were made out of 1/8" and fit well. For actual use I will probably go 3/16" or 1/4". You are correct with that that thickness of metal I will separate the "ears" from the piece that mounts to the block itself using the frame mount as a fixture to hold and line everything into place...thanks
DJC
Post by DJC »
try again
chevy sbc to frame mount.dxf
DJC
Post by DJC »
Okay think I get it posted as .dxf so people can cut it
I will try and post a pic as well in a little bit...
tinspark
Post by tinspark »
DJC wrote: Tue Dec 17, 2024 3:35 pm Okay think I get it posted as .dxf so people can cut it
Yep, you got it.
In the future if you post a dxf, know that when you post the lead ins etc. I am pretty sure it includes whatever kerf you compesated in the gauge that you saved it, and may not be as accureate to a guy who wants to cut out of a different gauge. A clean dxf of the original CAD drawing works best, letting the end user use his/her software adjust for kerf based on thier plasma cutter cut charts and gauge needing to be cut. FYI..
Looks good!
Doug,
Hypertherm 45XP-
chevy sbc to frame mount with dimensions.dxf
DJC
Post by DJC »
That's super cool, thanks for doing that with the dimensions! The triangular pieces are from a different set of mounts I built, was just using them to get the bolt spacing - thanks again!
