water tray
RONALD BERG
water tray
Post by RONALD BERG »
howdy i have a pcam4x4 want to add awater tray how far beneath the grate or should i say how close to the under side of the grate should i be thanks ron also how deep a tray should i use
Re: water tray
Ronald - I'm pretty sure we might have talked about this on one of the other Plasmacam forums. But - here is the link to a slide show for my water tray/draft system build.
https://photos.app.goo.gl/h8LHufi6frttfGNQA
RONALD BERG
Re: water tray
that is wow what else can i say you have taken out what percentage 0f dust also out side no filters or any thing its sucking it out correct thank you ron
Re: water tray
RONALD BERG wrote: Sun Mar 13, 2022 12:53 am that is wow what else can i say you have taken out what percentage 0f dust also out side no filters or any thing its sucking it out correct thank you ron
Yes - the draft system uses an exhaust fan to remove any remaining dust not trapped by the water tray.
