UCCNC & MiniTHC Path Rules and Post
Mr.Hotwire
Post by Mr.Hotwire »
Good evening, or morning almost now...
I have been working on getting my setup ready to do some light production. So.. I have been trying to improve by using path rules and tweaking my post.
Attached is a copy of my post, it is edited to turn the ohmic sensor on and off before and after probing. This prevents false triggers from HF. Also attached is a copy of my path rule set. Id like to know what your opinions are and if there is anything I should add or change.
Post :
Code: Select all
--*** Set these values up to suit your machine ***
--this is the distance between each torch reference in MILLIMETRES
refDistance = 1
--this is the reference feed rate in mm/min
refFeed = 2540
--Put your switch offset value here in MILLIMETRES
switchOffset = 0
--Scriber X,Y,Z offsets in MILLIMETRES. Do not use inches here even if you want inch code
--Use the special code 'nil' on the Z axis to disable it.
--In that case no Z values will be output at all while scribing.
--e.g scriberZ = nil
scriberX = 110
scriberY = 220
scriberZ = 0
--scriber axis. Leave this as nil if the scriber is fixed to the same axis as the torch
--scriberAxis = "A"
scriberAxis = nil
--If this value is set to true then use G28 (home) for the Z reference
--Set it to false for G31 probe
refHome = true
--The cutter will slow down for corners and turn off THC below this radius
slowRadius = 10
--Minimum slow down speed.
--This is a scale factor. For instance 0.5 = 50% of the current feed rate
slowPercent = 0.4
--THC on and off codes. Use nil if you don't want THC control e.g:
-- thcOnCode = m205
-- thcOffCode = m206
--here is another example that use M667 and M666
--thcOnCode = " M205"
--thcOffCode = " M206"
thcOnCode = " M205 "
thcOffCode = " M206 "
--***           End of settings                ***
function OnAbout(event)
   ctrl = event:GetTextCtrl()
   ctrl:AppendText("UCCNC w/ MiniTHC Post\n")
   ctrl:AppendText("\n")
   ctrl:AppendText("Modal G-codes and coordinates\n")
   ctrl:AppendText("Comments enclosed with ( and )\n")
   ctrl:AppendText("M03/M05 turn the torch on/off\n")
   ctrl:AppendText("M08/M09 turn the engraver on/off\n")
   ctrl:AppendText("Incremental IJ - set in mach2\n")
   ctrl:AppendText("The torch is referenced at cut start and every 500mm of movement thereafter\n")
   ctrl:AppendText("Designed for use with UCCNC with MiniTHC and Floating head\n")
   ctrl:AppendText("Post variables:\n")
   ctrl:AppendText("refDistance - set the distance between each reference\n")
   ctrl:AppendText("refFeed - set the feed rate when referencing\n")
   ctrl:AppendText("switchOffset - set your net switch offset amount \n")
   ctrl:AppendText("Scriber uses any tool number\n")
   ctrl:AppendText("slowRadius - slow down below this radius\n")
   ctrl:AppendText("slowPercent - minimum percentage to slow down\n")
end
-- Created 1/1/06
-- Based on plasma1.post
-- Modified 21/6/2010
-- Added: option for 'nil' plate marker z
-- Added: support for plate marker tool type as well as tool number based plate marker
-- Modified 4/11/2010
-- Added: Reference the torch on the first pen down if the plate marker is the first tool used.
-- Modified 21/7/2021
-- Changed: G31 Feed rate from 50 to 350
-- Fixed: Spelling errors
-- Added: Further command commenting
post.DefineVariable("refDistance",sc.unitLINEAR,0,1e17)
post.DefineVariable("refFeed",sc.unitFEED,0,1e17)
post.DefineVariable("switchOffset",sc.unitLINEAR,-1e17,1e17)
post.DefineVariable("slowRadius",sc.unitLINEAR,-1e17,1e17)
post.DefineVariable("slowPercent",sc.unitPERCENT,-1e17,1e17)
function OnInit()
   offX = 0
   offY = 0
   offZ = 0
   post.SetCommentChars ("()", "[]")  --make sure ( and ) characters do not appear in system text
   post.Text (" (Filename: ", fileName, ")\n")
   post.Text (" (Post processor: ", postName, ")\n")
   post.Text (" (Date: ", date, ")\n")
   if(scale == metric) then
      post.Text (" G21 (Units: Metric)\n") --metric mode
   else
      post.Text (" G20 (Units: Inches)\n") --inch mode
   end
   post.Text (" F1\n G53 G90 G40\n")
   minArcSize = 0.2 --arcs smaller than this are converted to moves
   firstRef = true
   currentZAxis = "Z"
   dist = 9999999
   lastz = 0
   thcstate = 1
   ThcOff()
end
function OnNewLine()
   post.Text ("N")
   post.Number (lineNumber, "0000")
   lineNumber = lineNumber + 10
end
function OnFinish()
   endZ = safeZ
   OnRapid()
   endX = 0
   endY = 0
   offX = 0
   offY = 0
   offZ = 0
   OnRapid()
   post.Text (" M05 M30\n")
end
function OnRapid()
   if(endX > 1e17 and endY > 1e17) then return end
   local len = math.hypot((endX + offX)-currentX , (endY + offY)-currentY)
   dist = dist + len
   post.ModalText (" G00")
   post.ModalNumber (" X", (endX + offX) * scale, "0.0000")
   post.ModalNumber (" Y", (endY + offY) * scale, "0.0000")
   if(offZ and firstRef == false and currentZ ~= safeZ) then
      post.ModalNumber (" " .. currentZAxis, (endZ + offZ) * scale, "0.0000")
   end
   post.Eol()
end
function OnMove()
   local len = math.hypot(endX - currentX , endY - currentY)
   dist = dist + len
   if(len > slowRadius) then
      ThcOn()
   end
   post.ModalText (" G01")
   if(offZ) then
   end
   post.ModalNumber (" F", feedRate * scale, "0.0###")
   post.Eol()
end
function OnArc()
   local radius = math.hypot(currentX - arcCentreX, currentY - arcCentreY)
   dist = dist + radius * math.abs(arcAngle)
   if (radius < slowRadius) and (math.abs(arcAngle) > 0.5) then
      feed = (radius / slowRadius)
      if(feed < slowPercent) then
         feed = slowPercent
      end
      feed = feed * feedRate
      ThcOff()
   else
      feed = feedRate
      ThcOn()
   end
   if(arcAngle <0) then
      post.ModalText (" G03")
   else
      post.ModalText (" G02")
   end
   if(offZ) then
   end
   post.Text (" I")
   post.Number ((arcCentreX - currentX) * scale, "0.0000")
   post.Text (" J")
   post.Number ((arcCentreY - currentY) * scale, "0.0000")
   post.ModalNumber (" F", feed * scale, "0.0###")
   post.Eol()
end
function ThcOff()
   if(not thcOffCode) then return end
   if(thcstate ==1) then
      thcstate = 0
      post.Text(thcOffCode)
      post.Text(" (THC off)\n");
   end
end
function ThcOn()
   if(not thcOnCode) then return end
   if(toolClass == "MarkerTool") or tool > 99 then return end
   if(thcstate ==0) then
      thcstate = 1
      post.Text(thcOnCode)
      post.Text(" (THC on)\n");
      return
   end
   if(thcstate == 2) then
      thcstate = 0
   end
end
function OnPenDown()
      if (firstRef) then
         Reference()
         post.Text(" Z")
         post.Number (safeZ  * scale, "0.0000")
         post.Eol()
         offX = scriberX
         offY = scriberY
         offZ = scriberZ
         post.ModalNumber (" X", (currentX + offX) * scale, "0.0000")
         post.ModalNumber (" Y", (currentY + offY) * scale, "0.0000")
         post.Eol()
      end
      if (offZ) then
         post.ModalNumber (" " .. currentZAxis, (currentZ + offZ)  * scale, "0.0000")
         post.Eol()
      end
      post.Text(" M08 9(spindle on)\n")
   else
      if(dist >= refDistance) then
         dist = 0
         Reference();
      end
      post.Text(" Z")
      post.Number (pierceHeight  * scale, "0.0000")
      post.Eol()
      if (preheat > 0) then
         post.Text ("\n G04 P")
         post.Number (preheat,"0.###")
         post.Eol()
      end
      post.Text ("\n M213\n M10.2 M03 (Ohmic Off / Torch on)\n")
   end
   if (pierceDelay > 0) then
      post.Text (" G04 P")
      post.Number (pierceDelay,"0.###")
      post.Eol()
   end
--   thcstate = 2 --leave THC off for plunge move
end
function Reference()
   firstRef = false
   if (refHome) then
        post.Text (" M10.1 G31 F350 Z-50 (Ohmic On)\n")
     -- post.ModalText(" G28.1 Z")
     -- post.Number(3 * scale, "0.00")
   else
      post.ModalText(" G31 Z -100")
   end
  -- post.ModalNumber (" F", refFeed * scale, "0.0###")
   --post.Eol()
   post.ModalText(" G92 Z0.0\n")
   post.Text(" Z")
   post.Number (switchOffset * scale, "0.0000")
   post.Eol()
end
function OnPenUp()
   if(tool > 99) then
      post.Text(" M09\n")
   else
      post.Text (" M214\n M05 (Torch off)\n")
   end
   if (endDelay > 0) then
      post.Number (endDelay,"0.###")
      post.Eol()
   end
end
function OnNewOperation()
   post.Text (" (Operation: ", operationName, ")\n")
end
function OnToolChange()
    if (toolClass == "MarkerTool"  or tool > 99 ) then
         ThcOff()
         if(scriberAxis and scriberAxis ~= currentZAxis) then
            endZ = safeZ
            OnRapid()
            currentZAxis = scriberAxis
         end
         if(firstRef ~= true) then
            offX = scriberX
            offY = scriberY
            offZ = scriberZ
         end
    else
         if(scriberAxis and scriberAxis == currentZAxis) then
            endZ = safeZ
            OnRapid()
            currentZAxis = "Z"
         end
         offX = 0
         offY = 0
         offZ = 0
    end
end
function OnNewPart()
   post.Text(" (Part: ",partName,")\n");
end
function OnDrill()
   OnRapid()
   currentX = endX
   currentY = endY
   OnPenDown()
   endZ = drillZ
   OnMove()
   OnPenUp()
   endZ = safeZ
   OnRapid()
end
function OnComment()
  post.Text(" (",commentText,")\n")
end
Path Rules :
Thank you for any and all comments or suggestions in advance.
Re: UCCNC & MiniTHC Path Rules and Post
Not an expert again, I think the "path rules" are active during the cutting operation. And what you want to do is at the start of the operation, I think your changes to the post in the "function OnPenDown" is the right location. You may need to also have the macros spelled out in another place, like "code Snippets" I would send off an email to Les at SheetCam to get clarification, or directions on how to do it.
You can look at the G-code to see where or if the M command is in there, I think it should be before the M3 to fire the torch.
robertspark
Post by robertspark »
your M10.x codes are fine, they are synchronous m-codes in uccnc and they do not require motion such as M10/M11 does.
you can do other things with the post processor and c-aixs protocol to send the voltage setpoint to the miniTHC.
your path rules look fine too, but I normally tweak those once you've been cutting for a while to improve / change things.
get the machine cutting first and then add the bells, and whistles / go faster stripes to improve things for you and your machine.
below is my miniTHC post processor that I used with UCCNC and the miniTHC. Please note, I no longer use the miniTHC or UCCNC for plasma cutting and have not used it for a while.
if you have a look through it it will show you the c-axis protocol and allow you to send your voltage to the minithc (you will have to set up the c-axis in uccnc).
it also has a the sheetcam rotary axis in the post processor as I use it for tube cutting occassionally (not used it for a while).
Code: Select all
--set it to -1 if you never want to reference
refDistance = 0
refFeed = 1200 -- 20mm/sec
switchOffset = 0.6
--Marker X,Y,Z offsets in MILLIMETRES. Do not use inches here even if you want inch code
--e.g markerZ = nil
markerX = 10
markerY = 20
markerZ = 0
--marker axis. Leave this as nil if the marker is fixed to the same axis as the torch
--markerAxis = "A"
markerAxis = nil
refHome = false
slowRadius = 25
slowPercent = 0.6 -- 60% speed for corners
-- thcOnCode = nil
-- thcOffCode = nil
thcOnCode = " M205 (THC On)" -- THC On
thcOffCode = " M206 (THC Off)" -- THC Off
thcLock = " M211 (THC Down Lock)" -- THC Lock for corners / small radi
thcUnLock = " M212 (THC Down UnLock)" -- THC Un Lock
--Torch on code
torchOn = " M03 M10 (Torch ON)"
--Torch off code
torchOff = " M05 M11 M206 (Torch OFF)"
--torchOff = " M11 (torch OFF)"
--Marker DOWN code
markerDn = " M7" -- setup to output for pneumatic relay DOWN
--Marker UP code
markerUp = " M8" -- setup to output for pneumatic relay UP
--Marker off code
markerOff = " M9" -- setup to output for pneumatic relays Off
--rotary axis. Normally this would be "A"
rotaryAxis = "A"
--Number of units for one full revolution of the rotary axis
--Note: In Mach3 the axis should be defined as linear, not rotary!
unitsPerRev=12000
   ctrl:AppendText("NON Modal G-codes and coordinates\n")
   ctrl:AppendText("M10/M11 turn the torch on/off\n")
   ctrl:AppendText("M205/M206 turn the THC on/off\n")
   ctrl:AppendText("Incremental IJ - set in UCCNC\n")
   ctrl:AppendText("The torch is referenced at EVERY cut start\n")
   ctrl:AppendText("Designed for use with UCCNC, MiniTHC and Floating + Ohmic head  & scriber\n")
   ctrl:AppendText("Marker uses any tool number\n")
   ctrl:AppendText("With 4th Axis PlasmaRotary plugin\n")
end
--   created 1/1/06
--  added option for 'nil' plate marker z
--  Added support for plate marker tool type as well as tool number based plate marker
post.DefineVariable("refDistance",sc.unitLINEAR,-1,1e17)
-- ADD IN Custom Voltage a MiniTHC Delay settings.
post.DefineCustomToolParam("PlasmaTool", "MiniTHC volts", "MiniTHCVolts", sc.unit0DECPLACE, 130, 0, 200)
post.DefineCustomToolParam("PlasmaTool", "MiniTHC delay -hundreths sec", "MiniTHCDelay", sc.unit0DECPLACE, 1, 1, 20)
post.DefineCustomToolParam("PlasmaTool", "Min Cut Length for THC", "minLength", sc.unit1DECPLACE, 1, .0, 6)
post.DefineCustomToolParam("PlasmaTool", "Soft Pierce Percent", "softPierce", sc.unit0DECPLACE, 0, 0, 100)
post.DefineCustomToolParam("DrillOperation", "Peck Delay", "peckPierce", sc.unit0DECPLACE, 300, 0, 2000)
post.DefineCustomToolParam("DrillOperation", "Peck Height", "peckHeight", sc.unit1DECPLACE, 3.8, 0.5, 5)
post.DefineCustomToolParam("DrillOperation", "Soft Mark Percent", "softPeck", sc.unit0DECPLACE, 50, 10, 100)
post.DefineCustomToolParam("JetOperation", "THC ON/ OFF (1/0)", "thcOff", sc.unit0DECPLACE, 1, 0, 1)
function OnInit()
   offX = 0
   offY = 0
   offZ = 0
   else
   end
   post.Text (" G53 G90 G91.1 G40\n")
   post.Text (" G92 X0 Y0 Z0\n")
   minArcSize = 0.05 --arcs smaller than this are converted to moves
   firstRef = true
   currentZAxis = " Z"
    if(MiniTHCVolts) then
--don't do anything
   else
     MiniTHCVolts = 0 --don't pass a null
end
if(MiniTHCDelay) then
--don't do anything
   else
     MiniTHCDelay = 0 --don't pass a null
end
if(thcOff) then
--don't do anything
   else
     thcOff = 0 --don't pass a null
end
   dist = 9999999
   lastz = 0
   thcstate = 0
   ThcOff() --sets THC off at beginning
end
   post.Text ("N")
end
function OnFinish()
   endZ = safeZ
   OnRapid()
   endX = 0
   endY = 0
   endA = 0
   offX = 0
   offY = 0
   offZ = 0
   OnRapid()
   post.Text (" M30\n")
end
function OnRapid()
	if (endZ == pierceHeight) then return end
	dist = dist + len
	post.Text (" G0")
   post.ModalNumber (" Z", (endZ + offZ) * scale, "0.0000")
   post.ModalNumber (" " .. rotaryAxis, endA, "0.0000")
	post.Eol()
end
function OnMove()
	--if(toolClass ~= "MarkerTool" and endZ < currentZ and endZ == cutHeight and softPierce == 0) then --this is a Z move on plasma plunge
	--	ThcLock()
	--	post.ModalText (" G00)
	--	post.ModalNumber (" Z", endZ * scale, "0.0000")
	--	post.Text ("( Pierce Plunge )")
	--	post.Eol()
	--end
	--if(toolClass ~= "MarkerTool" and endZ < currentZ and endZ == cutHeight and softPierce > 0) then --this is a Z move on SOFT plasma plunge
	--	ThcLock()
	--	post.ModalText (" G01")
	--	piercePlunge = 1
	--	piercePlunge = (softPierce / 100)
	--	feedRate2 = (feedRate * piercePlunge) -- lower the feedrate for soft pierce
	--	post.ModalNumber (" F", feedRate2 * scale, "0.0###")
	--	post.Text ("( Soft Pierce Plunge )")
	--	post.Eol()
	--end
	--	if(toolClass ~= "MarkerTool" and endZ > currentZ) then return end
   -- if(toolClass ~= "MarkerTool" and endZ == currentZ) then return end
		local len = math.hypot((endX + offX) - currentX , (endY + offY) - currentY)
		dist = dist + len
      minTHCdist = feedRate / 180 -- 0.333 second of motion
		if (minTHCdist < len) then
         ThcLockOn()
      else
         ThcLockOff()
      end
		post.Text (" G1")
		post.Eol()
end
function OnArc()
	if (endX == CurrentX and endY == CurrentY) then return end
   if(endX < materialX1 and endY < materialX1) or (endX > materialX2 and endY > materialX2) then return end
   len = radius * math.abs(arcAngle)
	dist = dist + len
   if (radius < slowRadius) then
      feed = slowPercent * feedRate
      ThcLockOn()
	else
      feed = feedRate
      minTHCdist = feed / 180 -- 0.333 second of motion
      if (minTHCdist > len) then
         ThcLockOff()
      else
         ThcLockOn()
      end
	end
   if(arcAngle < 0) then
      post.Text (" G3")
   else
      post.Text (" G2")
   end
   post.NonModalNumber (" X", (endX + offX) * scale, "0.0000")
   post.NonModalNumber (" Y", (endY + offY) * scale, "0.0000")
   post.Text (" I")
   post.Number (((arcCentreX + offX) - currentX) * scale, "0.0000")
   post.Text (" J")
   post.Number (((arcCentreY + offY) - currentY) * scale, "0.0000")
   post.NonModalNumber (" F", feed * scale, "0.0###")
   post.Eol()
end
function ThcOff()
   if(not thcOffCode) then return end -- ThcOffCode = nil (i.e. don't use THC)
   if(thcstate == 1) then
      thcstate = 0
   end
end
function ThcOn()
   if(not thcOnCode) then return end -- ThcOnCode = nil (i.e. don't use THC)
   if(thcOff == 0) then return end -- THC not required by operation
   if(toolClass == "MarkerTool") or (toolClass == "DrillTool") then return end
   if(thcstate == 0) then
      thcLockstate = 0
      thcstate = 1
      return
   end
end
function ThcLockOn()
   if(thcstate == 0) then return end -- THC not required by operation
   if(thcLockstate == 0) then
      thcLockstate = 1
      post.Text(thcLock)
      post.Text(" (THC Lock)\n")
      return
   end
end
function ThcLockOff()
   if(thcLockstate == 1) then
      thcLockstate = 0
      post.Text(thcUnLock)
      post.Text(" (THC UnLock)\n")
      return
   end
end
		if (toolClass == "DrillTool") then
			Reference()
			offZ = (peckHeight)
			post.Text (" G0 ")
			post.Text (" Z", offZ * scale, "0.0000")
			post.Eol()
         post.Text ("\n" .. torchOn .. "\n")
			post.Text (" G4 P", peckPierce, "\n")
         end
       if (toolClass == "MarkerTool") then
         offX = scriberX
         offY = scriberY
         post.NonModalNumber (" X", (currentX + offX) * scale, "0.0000")
			post.NonModalNumber (" Y", (currentY + offY) * scale, "0.0000")
			post.Eol()
			post.Text(markerDn .. "\n")
   		end
   else
      if(dist >= refDistance and refDistance >=0) then
         dist = 0
         Reference();
         post.ModalText (" G0")
         post.NonModalNumber (currentZAxis, (pierceHeight)  * scale, "0.0000")
         post.Eol()
      end
	   post.Text (" G4 P1500 \n")
      ThcOn()
			post.Text (" G4 P")
			post.Number (pierceDelay * 100,"0.###")
			post.Eol()
		end
	end
end
   firstRef = false
   if(refDistance < 0) then return end
   -- touch Off Macro (ohmic offset 0.1mm, 1.4mm switch offset)
   	post.ModalText(" M1031 (TouchOff)\n")
  end
function OnPenUp()
	if(toolClass == "MarkerTool") then
		post.Text(markerOff .. "(Marker Off)\n")
		post.Text(markerUp .. "(Marker Up) \n")
		post.Text(markerOff .. " (Marker Off) \n")
	else
		ThcOff()
      post.Text (torchOff .. "\n")
   end
end
	if (toolClass == "DrillTool" ) then
		post.Text (" (tool number: ", tool ," ")
		post.Text (" Plasma peck drill)")
		post.Eol()
	else
		post.Text (" Distance between Touch-offs: " , refDistance * scale, " ")
		post.Text (" Feedrate: ", feedRate * scale , ") \n")
      post.Text (" (ToolName: ", toolName , ") \n")
	end
	if (toolClass == "PlasmaTool") then
			post.Text (" (THC DISABLED for this tool)\n")
			ThcOff()
		else
       post.Text (" (THC ENABLED for this tool)\n")
		MiniTHCSetting()
		ThcOn()
		end
	end
         ThcOff()
         if(markerAxis and markerAxis ~= currentZAxis) then
            endZ = safeZ
            post.ModalText(" G0")
            post.ModalNumber (currentZAxis, (endZ + offZ) * scale, "0.0000")
            post.Eol()
            currentZAxis = " " .. markerAxis
         end
            offX = markerX
            offY = markerY
            offZ = markerZ
         end
   else
         if(markerAxis and markerAxis == currentZAxis) then
            endZ = safeZ
            OnRapid()
            currentZAxis = " Z"
         end
         offX = 0
         offY = 0
         offZ = 0
	end
end
end
function OnDrill()
	OnRapid()
	ThcOff()
	OnPenDown()
	OnPenUp()
	endZ = safeZ
	OnRapid()
end
function MiniTHCSetting()
	if(MiniTHCVolts > 0 and MiniTHCDelay > 0 ) then
         post.Text ( " G92 C0  \n" )
         post.Text ( " G0 C8   \n" )
         post.Text ( " G4 P100 \n" )
         post.Text ( " G0 C",MiniTHCVolts," (MiniTHC Voltage Setpoint) \n" )
         post.Text ( " G0 C",MiniTHCDelay," (MiniTHC Delay, hundreths of a sec) \n" )
         post.Text ( " G92 C0  \n")
         post.Text ( " G0 C5   \n" )
	elseif(MiniTHCVolts > 0 and MiniTHCDelay == 0 ) then
         post.Text ( " G0 C9   \n" )
	else
         post.Text ("(No THC Voltage / Delay Set, using previous settings) \n")
	end
end
package.path = sc.Globals:Get().thisDir .. "/plugins/RotaryPlasma/?.lua"
require("rotaryhelper")
djreiswig
Post by djreiswig »
Do you use the same post for rotary and flat cutting? I hope to eventually finish my rotary, but I use a modified post for sheet and didn't know what all needed to be different to do rotary. It would be cool to use one post for everything.
robertspark
I did (I don't use uccnc any more).
Mr.Hotwire
robertspark wrote: Sat Jan 08, 2022 2:25 pm your M10.x codes are fine, they are synchronous m-codes in uccnc and they do not require motion such as M10/M11 does.
Code: Select all
refDistance = 0
switchOffset = 0.6
--e.g markerZ = nil
markerX = 10
markerY = 20
markerZ = 0
--markerAxis = "A"
markerAxis = nil
refHome = false
slowRadius = 25
-- thcOnCode = nil
-- thcOffCode = nil
--Torch on code
--Torch off code
--Marker DOWN code
--Marker UP code
--Marker off code
rotaryAxis = "A"
unitsPerRev=12000
end
--   created 1/1/06
function OnInit()
   offX = 0
   offY = 0
   offZ = 0
   else
   end
   firstRef = true
   currentZAxis = " Z"
--don't do anything
   else
end
--don't do anything
   else
end
if(thcOff) then
--don't do anything
   else
end
   dist = 9999999
   lastz = 0
   thcstate = 0
end
   post.Text ("N")
end
function OnFinish()
   endZ = safeZ
   OnRapid()
   endX = 0
   endY = 0
   endA = 0
   offX = 0
   offY = 0
   offZ = 0
   OnRapid()
end
function OnRapid()
	dist = dist + len
	post.Text (" G0")
	post.Eol()
end
function OnMove()
	--	ThcLock()
	--	post.Eol()
	--end
	--	ThcLock()
	--	piercePlunge = 1
	--	post.Eol()
	--end
		dist = dist + len
         ThcLockOn()
      else
         ThcLockOff()
      end
		post.Text (" G1")
		post.Eol()
end
function OnArc()
	dist = dist + len
      ThcLockOn()
	else
      feed = feedRate
         ThcLockOff()
      else
         ThcLockOn()
      end
	end
      post.Text (" G3")
   else
      post.Text (" G2")
   end
   post.Text (" I")
   post.Text (" J")
   post.Eol()
end
function ThcOff()
      thcstate = 0
   end
end
function ThcOn()
      thcLockstate = 0
      thcstate = 1
      return
   end
end
      thcLockstate = 1
      post.Text(thcLock)
      return
   end
end
      thcLockstate = 0
      return
   end
end
			Reference()
			offZ = (peckHeight)
			post.Text (" G0 ")
			post.Eol()
         end
         offX = scriberX
         offY = scriberY
			post.Eol()
   		end
   else
         dist = 0
         Reference();
         post.Eol()
      end
      ThcOn()
			post.Text (" G4 P")
			post.Eol()
		end
	end
end
   firstRef = false
  end
function OnPenUp()
	else
		ThcOff()
   end
end
		post.Eol()
	else
	end
			ThcOff()
		else
		MiniTHCSetting()
		ThcOn()
		end
	end
         ThcOff()
            endZ = safeZ
            post.Eol()
         end
            offX = markerX
            offY = markerY
            offZ = markerZ
         end
   else
            endZ = safeZ
            OnRapid()
            currentZAxis = " Z"
         end
         offX = 0
         offY = 0
         offZ = 0
	end
end
end
function OnDrill()
	OnRapid()
	ThcOff()
	OnPenDown()
	OnPenUp()
	endZ = safeZ
	OnRapid()
end
	else
	end
end
RS, thank you again. You always come through.
The C-Axis is my next hurdle, I need to sort UCCNC and SheetCAM out to use it. Your post will help out a ton. I have it cutting, and I have THC and the MiniTHC with Ohmic working well.
My issue right now is speed... My machine can't move fast enough to cut the 18g cleanly. But that's due to my use of ball screws rather then R&P.
Here's where I am now...
djreiswig
Post by djreiswig »
Looks good. You should be able to rotate your parts and nest them tighter in SheetCam to more efficiently use your material.
Mr.Hotwire
djreiswig wrote: Sun Jan 09, 2022 3:11 pm Looks good. You should be able to rotate your parts and nest them tighter in SheetCam to more efficiently use your material.
Each one of them holes was from doing test cuts, of more and more complex shapes. So its kind of expected LOL. However, Nesting in SheetCAM when I start production parts will def be a huge help.
Thanks again!
robertspark
ballscrews will be a problem, one way to overcome it is to lower the amperage, given you are cutting thin material
a starting point will be say a 20% lower amperage and a 20% lower feedrate.......
What some of the guys do is they create a "job" for each sheet that they cut, and they save the job file for that sheet, so that if they want to add parts to better use the material they call up that job fine and then position the new pieces on that job / sheet so they use the whole sheet.
(I am not so good or organised, and just set a temporary offset and restart from the new point).
You can create an "L" shape on the corner of your table that you can use as an index point for material you place on the table so that all of the "job" sheets in sheetcam roughly line up.
If I was to use plasma for money generation (and not a hobby) I would do it that way, as I only cut odd things for myself.
djreiswig
Post by djreiswig »
robertspark wrote: Sun Jan 09, 2022 4:23 pm What some of the guys do is they create a "job" for each sheet that they cut, and they save the job file for that sheet, so that if they want to add parts to better use the material they call up that job fine and then position the new pieces on that job / sheet so they use the whole sheet.
This is what I do. I name the job with the material thickness and the date. I usually try and use up one sheet before I start the next. I zero at the lower left corner and start adding parts to the upper right corner so I don't cut away my zero point. I mark the home corner on the top with a paint pen. Then when I come back the sheet later I can re-zero off of the corner and cut more parts.
In SheetCam, I lock parts after I cut them so I don't accidentally move them. Les added a new menu option, at my suggestion, to activate/deactivate locked parts. This makes it easy to turn them on so you can see where to place new things and then turn them back off when you post the new code.
I'm just doing hobby work. If you're doing production, you might want to come up with a serial numbering system and marking sheets with a paint pen to match the job name.
Mr.Hotwire
I'm just doing hobby work too, that being personal, friend and co-worker requests. Also some auto parts for friends and a local club.
I'm going to try out the 20% lower trick. I did just lower from 45 to 35 amps. I'll adjust the speed on my next cut. That being said, it still cut and left a lot of draws and a rough cut edge.
Return to “SheetCam”
