...our Flap Disc and Cut Off Wheel Combo Deal featuring CHOICE CUT 4.5” cut off wheels and Premier Grind 4.5" zirconia flap discs (German Made).
Priced at $35, this package includes:
25 – Premier Grind 4.5” x 7/8” Zirconia Flap Discs: Type 27 or Type 29 / 36, 40, 60, 80 or 120 Grit, and…
25 – CHOICE CUT 4.5” Cut Off Wheels: Type 1 (flat)...good for cutting steel and stainless steel.
In lots of 5, use the COMMENTS section to let us know types and grits for the flap discs, i.e. 5 - 36 Grit/T27, 10 - 60 Grit/T29, 5 - 80 Grit/T29 and 5 - 120 Grit/T27.
If you leave this blank, we'll default to 10 - 40 Grit/T29, 10 - 60 Grit/T29 & 5 - 80 Grit/29.
***Roark Supply is a leading provider of abrasives used by fabricators, as well as off-road and custom car enthusiasts.
