Koike table with Miller Spectrum 875 Auto-Line
I have a Koike table and controller and I want to update my plasma to a Spectrum 875 Auto-Line, my question will the controller run this cutter?
Re: Koike table with Miller Spectrum 875 Auto-Line
Don't see any reason why it wouldn't, you can put an air plasma on anything really. Miller has some automation cables for the 875 if your table has auto height control and requires an arc voltage signal and/or arc ok signal. What plasma cutter is currently on your table? Do you have auto height control and if so does it require raw or divided voltage? Does your table require an "arc OK" signal?
hypertherm 45 and yes to auto hight and I don't know about raw or devided
If you have HT45 on it now then yes no problem using the spectrum 875, whether you need raw or divided you can make it happen. If your HT45 has the CPC port for machine connection you will be divided voltage I am sure and it would be easier to get another Hypertherm plasma as it will likely just plug and play.
The Hypertherm CPC port is only available on the 45xp, 65, 85, etc. Not available for the 45.
I could be wrong, they may not call it a CPC port on the standard 45 however it looks, feels, and works like a CPC port so if your 45 has what looks like a CPC port that's what I was referring to. See page 3-26 of your manual for clarification.
