Flighting
- cstroke
Flighting
Not sure where to look, did a search on flighting but nothing popped up. I thought I read a thread where someone was talking about flighting but I cant find it now.
Anyone have a source of how to make simple flighting? I need to make a drum with flighting on the inside and am not sure how to draw it.
Flighting will fit inside a 36" drum that will measure 35 3/4" and be 5" tall 1/8" thick stainless It's traveling 128" 8 1/2 wraps in that distance.
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: Flighting
Flighting is rolled to make the inner dimension smaller than the outer dimension. I don't think there is any way to cut flighting unless you cut donuts and split them, stretch them and weld the ends together.
But I might be wrong.
Re: Flighting
Is this what you are looking for? This looks like something used on augers, or maybe inside a drum to be used for tumbling parts.cstroke wrote: Mon Aug 23, 2021 8:57 am Not sure where to look, did a search on flighting but nothing popped up. I thought I read a thread where someone was talking about flighting but I cant find it now.
Re: Flighting
Yup. That's flighting. But he's asking how to make it. He already seems to know what it is by his detailed description of what he is looking to make.
Re: Flighting
This video might be helpful in understanding how to make it. For this scenario, it would need to be made from multiple pieces and joined together. But I don't see that as being a problem for a "do-it-yourself" type application as described in the original post.
https://www.youtube.com/watch?v=PsBhPurfiG0
- cstroke
Re: Flighting
Yes I'm creating flighting for the inside of a "drum".
I got help from someone who can draw it in autocad 360 but the problem is getting it flattened out. It's not straight forward and there are work arounds from what I've read. The guy helping me couldn't flatten it but was able to draw it.
I might have to go old fashioned on it.
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: Flighting
I would be interested to see what you have with your autocad drawing. Maybe you could post a screen shot. If it is in Fusion 360, perhaps you could post the file so I can take a look.cstroke wrote: Fri Sep 03, 2021 9:44 am Yes I'm creating flighting for the inside of a "drum".
- cstroke
Re: Flighting
Is there a trick to be able to attach a step file?
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: Flighting
You could upload your step file ( or Fusion 360 file) to Google Drive, and then share the link for others to open. Here is an example where I saved a Fusion 360 file to my computer and then uploaded to Google Drive. You can click on the link below to download.
https://drive.google.com/file/d/10aaRSt ... sp=sharing
Re: Flighting
You could also convert your step file to stl format using this free online file converter, then upload your stl file to Google Drive and share download link.
https://anyconv.com/stp-converter/
Here it the download link from Google Drive.
https://drive.google.com/file/d/1wFKFMm ... sp=sharing
Here I opened the converted stl file with Solid Works.
You could also open/import the stl file with Fusion 360.
- cstroke
Re: Flighting
https://drive.google.com/drive/folders/ ... sp=sharing
See if this works.
See if this works.
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: Flighting
Yes - it works. I don't see any way to cut that whole thing from flat sheet metal as a single part. It is like a coil spring - I think you will need to cut the individual coils and fasten them together.
Re: Flighting
Yes. As I stated above, you can make flighting by cutting donuts the correct diameter and stretching them and welding the ends together.
Re: Flighting
I also linked an instructional video above.djreiswig wrote: Mon Sep 06, 2021 12:34 pm Yes. As I stated above, you can make flighting by cutting donuts the correct diameter and stretching them and welding the ends together.
- cstroke
Re: Flighting
Yes I knew the ring would need to be cut stretched out in the direction of travel and then the 5" flats welded together.
Was just trying to figure out how to make the short section bottom drawing you posted as a flat pattern.
I don't think it's a 38.09x 28.09 circle with sliced it would be more stretched out than that wouldnt it?
Maybe I'm overthinking this
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: Flighting
It this the "short section bottom drawing" you are asking about?cstroke wrote: Tue Sep 07, 2021 4:50 pm
- cstroke
Re: Flighting
Yes just the short section.
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: Flighting
I would cut a paper or cardboard pattern and fit it to the inside of your drum. When you bend it, I think it will tend to come in on the sides - but when you test your pattern it will tell you how much you need to add. Then modify your pattern until it fits right when you bend it and fit it inside the drum. Then you can create a cad drawing of your pattern. For me, I would use either my digitizing board or scanything auto tracer to convert the pattern to dxf. You could send me your finished pattern (paper or cardboard) and I will digitize it for you. I will send pm.
- cstroke
Re: Flighting
Yes, I figured I'd end up doing it the old fashioned way LOL...
It's not a problem drawing it in 2d, once I have the cardboard cut out. I know there has to be a way to model it in 3d and make a flat pattern.
It's just one of those perplexing ones...
I'm fairly proficient with drawing so it's not that big of a deal.
I appreciate everyones help here though.
CHRIS
CHRIS
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: Flighting
Chris - I am not aware of a way to convert a spring coil, which is effectively what this is, to a flat pattern in Fusion 360. If you find out how to do it, I would be very interested to learn your method.cstroke wrote: Tue Sep 07, 2021 7:56 pm I know there has to be a way to model it in 3d and make a flat pattern.
- tinspark
Re: Flighting
Triangulation. The radius will lay out larger than the pipe and as it stretches to the correct rise. Once the rise run, and ultimately the radius are established, yes they are just flat donut discs with a splice cut through. on heavy gauge augers we used to tac weld one end down and stretch the other end to the required rise after the pattern was established. .But instead of welding a pipe to the smaller radius like a typical auger, the radius will attach to the larger radius of a drum.
If you need a copy of a layout method I can see if I can find it in the archives and take a picture tomorrow or when I can.. I haven't done one in prolly a decade, but never the had need for attaching to the outside just an auger application. Should be the same layout development though..
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
- tinspark
Re: Flighting
See if this does it. Free online calculator. LOL!! figure it draw it and burn
https://www.easycalculation.com/enginee ... -screw.php
Edit: Here is another free calculator.
https://www.modelbuildings.org/helix-design-calculator/
Doug,
Hypertherm 45XP-
Hypertherm 45XP-
Re: Flighting
Doug - those both look very "handy", and easy to use. I especially like the first one. I will look forward to hearing how Chris makes out with them.tinspark wrote: Fri Sep 10, 2021 2:00 am See if this does it. Free online calculator. LOL!! figure it draw it and burn
- tinspark
Re: Flighting
What I like about the second one is that it explains how to figure pitch percentage as requested in either one of the calculators..adbuch wrote: Fri Sep 10, 2021 3:18 amDoug - those both look very "handy", and easy to use. I especially like the first one. I will look forward to hearing how Chris makes out with them.tinspark wrote: Fri Sep 10, 2021 2:00 am See if this does it. Free online calculator. LOL!! figure it draw it and burn
Yes I agree the first one doesn't seem as janky.. train track flighting , Who would have thunk it.. lol!!!
Doug,
Hypertherm 45XP-
Hypertherm 45XP-
