Powermax 600 and machine torch
Twisted 1
Post by Twisted 1 »
Good afternoon
I have a Powermax 600 with the original hand torch and I’m looking to upgrade to the 228920 torch for my PlasmaCam DHC machine. Is there a noticeable difference in cut quality and consumable life. My 600 has maybe 50 hours on it but the consumables for the hand torch are discontinued. Also is there anything special I need to do you make it work, such as wiring inside the machine. Thanks in advance
Pete
Twisted Image Customs and Fabrication
Ontario Canada
weldguy
Re: Powermax 600 and machine torch
Post by weldguy »
I believe you will see a noticeable improvement in cut quality and consumable life with the Duramax torch your looking at. That part number you listed should be a plug and play setup however with the 600 I am sure you will have to open the machine to make the connections inside.
t-tracks
Post by t-tracks »
i have 2 machine torches i would sell for the 600
Twisted 1
Post by Twisted 1 »
T-tracks
I sent you a PM
Pete
Ontario Canada
