So i pulled the trigger
So i pulled the trigger and purchased a new candcnc blade runner g5 package with all the bells and wistles. Also bought a gantry kit through precision plasma and cutting edge plasma. Just waiting for everything to arrive so i can order steel and build a 4x8 with water table. Only question i have is what homing switches do you guys recommend. I thought the candcnc came with them. They do but only for z axis. nothing for table. If im spelling it right david from candcnc recommend moujen switches.. Problem is i dont know what size or kind to get. Any help would be great. I have a crossfire plasma table now and all though it is a good little machine for small stuff it lacks alot of stuff i will have with new table. Also i have a hypertherm pm 85 with cpc and rs485 running a machine torch.
Crossfire Plasma Table
Hypertherm pm 85 cpc rs-485
Miller 252 mig
Miller dynasty 280 Tic/stick
Metabo Mag drill
various Fab equipment
4x8 precision plasma table
G5 c and cnc controls
“ the Shop “ were it all happens
Miller 252 mig
Metabo Mag drill
Re: So i pulled the trigger
Also thinking about buying one of the sharpe 3 stage dryers from plasma spider. I have a motor gaurd and some small seperator stuff.
Miller 252 mig
Metabo Mag drill
Miller 252 mig
Metabo Mag drill
Also thinking of putting a cutzilla air scribe on plasma build. I talked to josh the owner and he said he doesnt know if it will work with c and cnc. that once i build i have to determine there signal for scribe power wise and he would let me know if it will work. if anyone has any info to add on that i would appreciate it.
Miller 252 mig
Metabo Mag drill
Miller 252 mig
Metabo Mag drill
Right on man. Sounds like you will be busy over the holidays! Exciting stuff! Good luck with your build
I have an air scribe. Just run the air valves off of one of the accessory outlets.
Sounds like you are in for a rewarding job!
Switches https://www.amazon.com/Omron-SS5GL2-Mic ... 653&sr=8-1
Or anything like that. That is the style i used, you can buy those huge ones with adjustable levers but these take less space
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Ermaksan Brake
10x40 lathe
2-Miller 255
Miller XMT350MPA
