It’s our Flap Disc and Cut Off Wheel Combo Deal featuring Premier Grind 4.5" zirconia flap discs (German Made) and CHOICE CUT 4.5” cut off wheels.
Priced at $35, this package includes:
25 – Premier Grind 4.5” x 7/8” Zirconia Flap Discs: 10 – 40 Grit, 10 – 60 Grit, 5 – 80 Grit, and…
25 – CHOICE CUT 4.5” Cut Off Wheels Type 1 (flat)...good for cutting steel and stainless steel.
A little change from in the past with regards to selecting the flap discs…
In lots of 5, use the COMMENTS section to let us know types and grits for the flap discs, i.e. 5 - 36 Grit/T27, 10 - 60 Grit/T29, 5 - 80 Grit/T29 and 5 - 120 Grit/T27.
If you leave this blank, we'll default to 10 - 40 Grit/T29, 10 - 60 Grit/T29 & 5 80 Grit/29
***Roark Supply is a leading provider of abrasives used by fabricators, as well as off-road and custom car enthusiasts.
